TS Reflash= RIP OFF?
Old Jan 17, 2006 | 07:49 AM
  #41
pln2311's Avatar
pln2311
Where do I get a UTECH in Kansas?
Old Jan 17, 2006 | 08:35 AM
  #42
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Chebosto
As far as self adjustability, yes. Utec can't be beat. for $1800 in parts and tuning, you better get every you need. NA or FI...
For me and others who dont want the hassle of trying to finding an authorized tuner, a flash can do everything i want the car to do to while safely boosting up to 1 bar for 1/3rd the cost. I abuse the Z just as hard as anyone can imagine. and i'm fine with my reflash. I'm biased against the fact that the thread started claimed it as a Rip Off. and i highly disagree with that statement.
Well lets see..There are like 2 places in the country that do TS reflashes on their dyno..Opposed to over 100 TX dealers/tuners.. Second the UTEC installed and tuned runs about $1300for N/A and $1600 for F/I..As far as you telling me that RPM based fueling of a FI car is a good idea, no way..Its good if you live in a steady climate and altitude like Cali, but what happens when you experience changin weather and altitude conditions, how does the REFLASH account for additional boost perssure due to more dense air?
Old Jan 17, 2006 | 04:29 PM
  #43
InsaneChink's Avatar
InsaneChink
ok so let me get this straight. Since i am local, i can have TS custom flash my ECU to my mods. But before that i need to give them a dyno (75.00). Then after the flash i have to dyno(75.00) it again to see if they did it right?
Old Jan 17, 2006 | 04:35 PM
  #44
jeremybudd's Avatar
jeremybudd
I was under the impression that if you are local you just go down and they tune it while they dyno at TS. So you will probably only have to pay for 1 dyno session.
Old Jan 18, 2006 | 08:37 AM
  #45
Chebosto's Avatar
Chebosto
prior to heading down there, an A/F readout and dyno would be preferred. You should call them first if u have questions. They do have an A/F measurement device there, however it is for final tuning purposes.
Old Jan 18, 2006 | 09:17 AM
  #46
Julian@MRC's Avatar
Julian@MRC
That makes no sence...How is an A/F device used only for a final tune?Dont they do a pre-and post tune A/F??
Old Jan 18, 2006 | 11:30 AM
  #47
InsaneChink
yea im really confused. I callde them and they said that they dont have a dyno there, so how do they know if the reflash was done correctly??
Old Jan 18, 2006 | 12:37 PM
  #48
Chebosto's Avatar
Chebosto
They use the wideband sensor to check the final A/F ratio after the tune. They'll hook up the sensor to the tail pipe, and their comptuer to the OBDII port to pull timing and other codes to make sure the ECU flash was done correctly.
The A/F device is not used solely for the final tune, i don't understand why you must assume that's the only thing they do.
Old Jan 18, 2006 | 01:55 PM
  #49
mrtomcat's Avatar
mrtomcat
let's also not forget that there was no UTEC for for Z until VERY recent...
For what's it's doing I think it's an excellent product and not even close to being a ripoff. I'm happy with my TC Reflash even though I just use the L-Spec.
They are both good products everyone needs to make up there own mind on what's best for their need.
Old Jan 18, 2006 | 02:52 PM
  #50
steela2110's Avatar
steela2110
I would say go with UNICHIP or UTEC
Old Jan 18, 2006 | 07:17 PM
  #51
sja177's Avatar
sja177
I think you guys voting for utec may be just as biased as chobesto is for TS reflash.
I just got TS reflash done today actually and the gain was huge in the midrange. I was running lean and now I have a perfect 13.1-13.2 afr. They added more fuel to the map, more timing, and the car now feels much smoother and faster. I also have a nice 7100rpm redline. For $600, it is the best mod I have done to date.
Motordyne 5/16 with iso thermal
Stillen Headers
Test Pipes
Y Pipe
JWT Intake
Old Jan 18, 2006 | 07:44 PM
  #52
zland's Avatar
zland
Sport Z Magazine
I personally feel the thread started out in a negative tone by bashing TC. Then when Chebosto gave a different opinion then those pro UTEC, he was bashed pretty much for giving it. Just because he likes TC's product and even if they sponsor him as well does not mean he cannot have valid points. Saying a persons opinion means “squat” is not the way to start a meaningful discussion.
Most often, whatever a person buys/selects for their car, they tend to defend it be it is an exhaust or a turbo kit. Most of us do this unfortunately, just like when a WRX or RX8 owner comes on our forum; it is not uncommon for Z owners to be biased toward our Z's.
I feel we need to rise above this behavior, grow up a bit and agree to be kind to each other and respect each other even when we disagree. There is no benefit to being abrasive when discussing an issue. Most of us are adults, not in high school. Why can't we discuss the pros and cons of each product? Instead of trying to prove one product is 100% better than another & maybe try looking and the strengths of each.
Old Jan 18, 2006 | 07:49 PM
  #53
zland's Avatar
zland
Sport Z Magazine
opps, sorry, double post.
Old Jan 21, 2006 | 08:31 PM
  #54
Rickdogg's Avatar
Rickdogg
Out of hiatus
https://my350z.com/forum/engine-and-drivetrain/166361-dyno-results-from-tuning-with-technosquare-and-motordyne.html
Old Jan 22, 2006 | 12:36 AM
  #55
FatBoy1's Avatar
FatBoy1
+1
Old Jan 22, 2006 | 05:47 AM
  #56
gringott's Avatar
gringott
Yes, started negative.
I have the PE kit, and when many told me to get the reflash, even at stock boost, Technosquare told me no, and spent the time to answer my questions, This was to stop someone from buying a product that was not needed. Ripoff? I don't think so.
The reason I went UTEC when I upped the boost rather than a reflash:
MAP based.
Adjustable via laptop without special software, shipping etc.
Reversable at no cost.
Disabled at any time.
If I was living in California, I would have reflashed. But I live in a four season environment, and needed a solution that accounted for that.
Old Jan 23, 2006 | 12:45 PM
  #57
Axelerate's Avatar
Axelerate
Can the rev-limiter be raised with the Utec?
Old Jan 23, 2006 | 12:50 PM
  #58
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yes
Old Jan 30, 2006 | 10:22 PM
  #59
dscheers's Avatar
dscheers
I would call your opinion a bit biased, as are mine for obvious reasons, however I will say there in nothing better than a custom tune on the car itself. Plus I am not comfortable with sending my ECU across the country in a box.But that is just me..Plus a Reflash does not store 5 seperate maps and offer data loging as well as free software upgrades and maps. The UTEC is far superior to a reflash in every way concievable..
I send my ECU from Panama to TS by Fedex, they send it back to Miami and from there it was flown back to Panama. No problem. I have an 5AT and was hitting constantly the Rev limiter. The reflash took care of that. I had to have the ATI fuel management box retuned since more air was coming into the engine (WOT 100% open, apparently it works). BTW: I only got a limited reflash...
Really interested in the Utec now...
Danny
3vilbunny
Jul 18, 2017 05:10 PM
Juztin
Nov 22, 2015 07:03 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
kelvkicks
May 14, 2003 02:01 AM
wadd3456
May 12, 2003 03:31 AM
