Iso Thermal Spacer question
Old Jan 29, 2006 | 11:21 AM
BootieMAN's Avatar
BootieMAN
Default Iso Thermal Spacer question
Do I use the stock manifold gasket with the iso thermal gasket or just the iso thermal gasket by itself?
Thanks in advance.
-Bootay
Old Jan 29, 2006 | 11:51 AM
Mr_pharmD's Avatar
Mr_pharmD
I have the same question. I believe u use both stock plus the one that comes with the kit.
Old Jan 29, 2006 | 11:55 AM
Daytona350Texas's Avatar
Daytona350Texas
heres how mine goes, the very bottom UNDER lower plenum, it says REPLACE gasket with iso thermal, then on lower plenum u RETAIN same gasket, then spacer, then gasket that CAME with kit, then top plenum, screw on, done
Old Jan 29, 2006 | 01:03 PM
RedBird's Avatar
RedBird
We have a winner!
Old Jan 29, 2006 | 01:32 PM
BootieMAN's Avatar
BootieMAN
Thanks people
Old Jan 29, 2006 | 01:57 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Reading instructions is crucial
Old Jan 29, 2006 | 04:53 PM
Midnyte's Avatar
Midnyte
if you ordered them from Motordyne, they may send you two. You can use both of the ones they send you together, but you toss your old stock gasket into the "parts" section of your garage
-Blaise
issyz
Jul 2, 2017 03:04 PM
