REVIEW... REV-UP plenum installed on 287HP motor!
Old Feb 7, 2006 | 05:14 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally Posted by Jokestrap
That's right... All have to remember that the rev-up has different cams than the 287. The cam phasing takes away some of this low end tq that you describe, though I will say that it still does start off slow and finish big...
Yes, but if you have a more aggressive intake cam it will do the same thing (like JWT Cams...)
Yes it starts off slow, it takes 1000 RPM to get to PEAK HP as stated in my post above...
But with the 287 Plenum... It takes 1400 RPM to get to Peak HP and it dies off rite away...
Old Feb 7, 2006 | 06:23 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice argument but it all goes away if you shift the non revup plenum at 6600rpm's, you will be in the meat of the powerband next gear. While the MREV pulls for a second more but loses tons of TQ/HP in the beginning of the next gear. I still say the red curve shifted at 6600rpm's would be faster down the 1/4 than the blue curve. And the same thing for road racing because you will use the midrange to propel you from the corners...we can argue about this all day/night, but at the end of the day my measly non revup motor trapped 107mph with a well shifted "laggy top end" powerband, now show me a revup thats done the same trap or better with 260ish whp. Proof is in the numbers...
Old Feb 7, 2006 | 06:45 PM
Z350Lover's Avatar
Z350Lover
I have got an 05 lower intake plenum from Jason too.... and my peak power has already shifted from 6500rpm or so to 7200-7300rpm and if my injectors were not maxed out, it would be kept at the peak all the way to 8000rpm on my car...
So with those shorter runners on the 05 lower intake plenum, you will definitely lose some low end torque and gain high end power... lucky me that I got those lower end torque back from running higher compression pistons and lighter rods..
cheers,
richie
Jason@Performance
Performance Nissan
5 ftlbs of torque is tons?
they shift down to about the same HP mark...
when looking at the graph you have to ignore the line infront of it...
if you were to re-draw the graphs so they are ontop of eachother the REV-UP plenum will make more power longer but have the same HP curve...
The only thing different is one makes the same power at a lower RPM...
I wish I could show you that I have proof that is in the numbers, but there are some things you just dont talk about when it comes to race motors that you dont want other teams copying... thats another story though...
Old Feb 7, 2006 | 06:50 PM
Jason@Performance
Performance Nissan
cheers,
richie
post your latest dyno in this thread
Old Feb 7, 2006 | 11:57 PM
Z350Lover's Avatar
Z350Lover
Jason.... here is the latest dyno that I have got compare to the previous one... Pay attention to the derived RPM on those 2 curves...
Latest... with high compression pistons, ferrea valve train set, carrillo rods , 2005 lower intake plenum and tunings...
This dyno chart was done without new pistons, rods, ferrea valvetrain set and 2005 lower intake plenum... (the power reading on the bottom of the dyno chart should be HP instead of KW)
cheers,
richie
Old Feb 8, 2006 | 12:13 AM
Jason@Performance
Performance Nissan
Wicked!
Old Feb 12, 2006 | 11:27 AM
VQ35deMax's Avatar
VQ35deMax
Originally Posted by Jason@Performance
This is a very arguable subject...
It comes down to the driver, the cars configuration etc etc...
When I had this set up on my car, unfortunatly I was not able to get my reflash done to run higher RPM like I was planning to... I had the parts to build my motor up to 7800-8000 RPM and make power up to...
With a motor that makes more power the shift points change to where you need to accelerate up to a certain point and then when you shift have the RPM fall into the optimal point in the power band to being accelerating into that next gear...
This is where we can look at the "M-REV" mod dyno's in reverse...
Below is a dyno of the M-REV dyno we did on a Rev UP motor...
M-REV mod is basicly 287 Lower Plenum on the 300HP rev up motor (Track Model Lower Plenum)...
We know the RevUP plenum makes for more power in the Higher RPM's
We know the M-REV mod changes powerband to make not as much power up top which is where the "Spacer" comes into play (Spacer can be in form of the Motordyne spacer, Crawford Plenum, Skunk2 spacer etc... all essentiaally do the same thing)...
So this is where it gets tricky...
We will use the 7000 RPM redline for example...
7000 RPM in 2nd gear with 3.53FD is 67MPH
4900 RPM in 3rd gear with 3.53FD is 67MPH
Assume that in the time you shift from 2nd to 3rd enertia is still acclerating the car you would fall into gear around 5200 RPM (ish)
Highlighted in Green is the REV-UP plenum modification:
Highlighted in Red is the 287 plenum modification:
Each block is exactly the same size representing the optimal shift points with said modifiaction:
Lets explore the REV-UP shift points...
Starting at 5200 RPM HP rating is just about 225RWHP. It accelerates to peak 266RWHP at 6200RPM and FLATLINES (making constant 266RWHP) until cut off at 7000 RPM. So it takes 1000RPM to get to Peak HP and maintain it. This same HP curve is seen on 287 Motors with JWT cams for example and a higher Rev Limiter. But shift points can be made even higher with the higher revlimiter to benifit the more constant peak HP... That is 750RPM spent in PEAK HP range while accelerating!
Lets explore 287 plenum shift points...
Starting at 4700 RPM HP rating is just about 225RWHP. It accelerates to peak 268RWHP at 6100 RPM and then Dies Off. So it takes 1400RPM to get to Peak HP but it then dies off. Only 400RPM spent making around Peak HP.
In short... The power seen from the 287 plenum is best for the Daily Driver who doesnt spend as much time in rapid acceleration... Yes the car feels more Torque in lower RPM with the 287 plenum but its the HP that pushes you through the corner and takes over in the higher RPM's, once the intial Moment of Enertia is in effect, the HP takes over...
You can look in the Dyno that the TQ is More while the HP is More at the higher RPM's as well...
If you run a HIGHER Rev Limiter with the Rev-Up plenum on a Rev-Up motor you can run to 7500RPM on stock internals safely and make power... You will beable to change your shift points up to 7500RPM and spend even more time making Peak HP while accelerating...
that is very interesting. accoring to the graph then nissan lied about the z having 300 hp then. but how a revup be with a spacer then? would it provide even more gains in the higher rpm range?
Old Feb 12, 2006 | 12:23 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Not necessarily. The power shown is at the wheels. Nissan advertises what is made at the crank. And there is indeed a significant amount of power lost through the drive train.
The REVUP engine may very well be making 300 at the crank but I don't know of anyone who actually put an engine on an engine dyno. That would cost big $$$
Old Feb 12, 2006 | 02:03 PM
bacalhau16's Avatar
bacalhau16
good write-up, lots of things to be learned here. Still glad i decided to go with just a spacer for my 287 motor.
Old Feb 14, 2006 | 08:34 AM
jcarp's Avatar
jcarp
I've Got The 06 Rev Up Motor And I Went With The Lower Intake And The Crawford Upper Intake And I Have Aem Cai And Borla Td's. I Havent Installed The Intakes Yet Just Ordered Them But Is There A Chance That The Will Kill The Torque.
Old Feb 14, 2006 | 08:43 AM
jcarp's Avatar
jcarp
thanks man yeah they say i got 300 hp and 260 ftlbs. i dont stay below 2500 anyways so it should do pretty good i'll let ya'll know when they come in and i put them on. gonna go fi shortly.
Old Feb 14, 2006 | 07:41 PM
Jason@Performance
Performance Nissan
im confused...
which plenum did you get? the 287 w/ longer runners?
if you have a rev-up you already have the plenum being discussed in this thread?
Old Feb 14, 2006 | 08:33 PM
bacalhau16's Avatar
bacalhau16
if ur confused and u sell the products, imagine how confused i am. Just when i thought i had a grasp on this...
Old Feb 14, 2006 | 09:18 PM
Jason@Performance
Performance Nissan
Im confused about jcarp talking about loosing torque.. the whole argument was the 300HP plenum lost torque in the lower power band, while the 287 plenum gained...
So I am trying to figure out if jcarp is ordering a part that is already on his car?
Thats what it sounds like he has ordered!
Old Feb 17, 2006 | 08:30 AM
jcarp's Avatar
jcarp
i talked to motor dyne and they said that it was different than the one on the car. its runners are longer to give it more torque that the motor is lacking and the are ported a little. i have the rev up motor and this intake is made for my car just a different version of factory for the new car. this is what i was told and if its the same peice i got i would be a little ticked.
Old Feb 17, 2006 | 08:32 AM
jcarp's Avatar
jcarp
http://www.motordyneengineering.com/350Z.asp
Old Feb 17, 2006 | 08:34 AM
  #38
Jason@Performance
Performance Nissan
Ok that is what I thought...
You are putting on the 287 lower plenum...
You have on your "Rev-UP" motor what in this thread is being put on 287 motors...
Old Feb 17, 2006 | 08:40 AM
  #39
jcarp's Avatar
jcarp
  #40
jcarp's Avatar
jcarp
Just A Little Insight Sorry Bud Wont Happen Again
