Correction....13HP & 14TQ Stillen Exhaust System!
Old Jan 20, 2003 | 02:40 PM
Mr Fairlady's Avatar
Mr Fairlady
Not a bad price either. I'm waiting for an ECU upgade before I mod, however
That is the best way....IMO as well!
Old Jan 20, 2003 | 03:34 PM
TXSTYLE's Avatar
TXSTYLE
Originally posted by articfury
The Stillen system doesn't use a Y-pipe. It uses an X-pipe, which bolts up to the Cats.
The HKS system uses an H-pipe. IIRC, the X-pipe design should perform better.
The Stillen layout is almost identical to the layout of my exhaust. Obviously, the Stillen is different because it is stainless and mandrel bent. They also use a set of resonators, which I have not done. (Juries still out on whether I want to do that.)
Marcus-
Since Saturday, I have been trying to notice where the power comes on. It is so unscientific, but it still feels like the low 3's when power comes on strong. I will say this, I have almost 2000 miles on the car with the exhaust, and until Brad mentioned that he felt like it is was slower that one time, I never noticed any point where it was slower. Does anyone know if this car has per gear fuel/timing mapping? I guess a dyno run with all the gears would solve the 3rd gear question.
I will be very interested to see the dyno sheets, and hear this exhaust.
JD
I haven't heard of the Z's per gear fuel/timing mapping, or if anyone has researched this. Good question. QAnd I too agree that a run thru all gears for proper comparison (dyno) would be wise. We shall see.... I have stated from the begining that this particular cars secret to releasing hp lies with the ECU/MAF. Once someone gets that right, we should see some "impressive gains" coupled with exhaust and intake.
TX
Old Jan 20, 2003 | 04:39 PM
nosuchsol's Avatar
nosuchsol
Stillen also claimed +25hp for their Z32 headers... And that was way overstated. $tealin
Old Jan 21, 2003 | 02:51 PM
Chebosto's Avatar
Chebosto
Default Re: Correction....13HP & 14TQ Stillen Exhaust System!
Mind you this is Stillen...
they also claim 8 hp gains from swapping cats and 9 hp from their intake for the Maxima.
13hp would be a miracle for any exhaust system.
im not getting my hopes up...
Originally posted by webcarconnection
Thats rigth 13hp & 14tq with Y pipe (all SS) and its price $1,095.00
http://www.stillen.com/morenews.asp?id=30
Old Jan 21, 2003 | 03:25 PM
bastard's Avatar
bastard
$2250 for 21 hp? are you insane?
Old Jan 21, 2003 | 03:31 PM
SandMan's Avatar
SandMan
13HP for around $1100
21HP for $2200, and not to mention the weight saving from all the full titanium setup. You wanna play, you gotta pay.
Old Jan 22, 2003 | 03:03 PM
sidemarker's Avatar
sidemarker
call me a newbie but how the hell do you get 21 hp from an exhaust?
is this including some type of exhaust manifold?
sidemarker
Old Jan 22, 2003 | 03:04 PM
sidemarker's Avatar
sidemarker
2200 is not far from a turbo kit that will definetely be worth the bang for the buck!
sidemarker
Old Jan 22, 2003 | 03:08 PM
SandMan's Avatar
SandMan
Yes it is quite pricey, but it isn't a turbo it is an exhaust, even if you have a turbo you will eventually need a good exhaust system to compliment it. So if you want to squeeze as much HP as possible, it will be expensive. I mean why would anyone buy a Rolex when they can buy 20 Casio. That could be said about anything, If your going to do it big, then it will cost you.
Old Jan 22, 2003 | 03:22 PM
webcarconnection's Avatar
webcarconnection
sidemarker
The Amuse system comes with a Y pipe that cut the Cats, there is a extra 10 rwhp for the system, w/o the Y pipe the system puts around 12 rwhp.
Old Jan 23, 2003 | 02:31 AM
integrate's Avatar
integrate
They cut the pre-cats. Not the main cat.
Old Jan 23, 2003 | 06:16 AM
westpak's Avatar
westpak
SFZCC
OK, I keep hearing about pre-cats and main cat, but on the diagrams I only see 2 cats and that is it, the center one is called center muffler, or as many call silencer, the y-pipe is called exhaust front tube and then you ave the main muffler, where is this main cat????
Old Jan 23, 2003 | 09:28 AM
integrate's Avatar
integrate
I think you're right....I thought there were 3 cats on this car. I also read from other people that there were the pre-cats as well as the main cat. Hmm, misinformation?
Old Jan 23, 2003 | 10:12 AM
articfury's Avatar
articfury
Charter Member #55
Notice that the description of the cats is, Three-way catalyst. This sounds like that they have put all three cats into that one larger chamber.
JD
Old Jan 23, 2003 | 09:24 PM
D'oh's Avatar
D'oh
The three way catalyst is not three different chambers, but instead a single chamber where the chemical reaction takes place.
I forget the formula for the reaction, but inside the catalytic converter is a fine mesh of material (in order to provide a large surface area for the reaction to take place) that is coated with the elements used in the reaction. IIRC, it is called a three way catalyst because there are multiple elements on the mesh and three reactions take place. You have something like:
A --> B
B --> C
C --> D
Where A is the unburned fuel remains and D is basically CO2 and H2O. B and C are intermediate hydrocarbons that eventually get converted to D.
Because lead will destroy the materials used in the converter, you cannot put leaded gasoline into modern cars since it will ruin their (the cat's, not the car's) performance.
The reaction requires heat in order to work, so the cats are placed as close to the exhaust ports as possible in order to allow the hot exhaust gasses to heat the cats as quickly as possible. This is also why some car makers are toying with the ideas of electrically pre-heated cats so the will begin working right when the car is started.
I think most of what I have posted is close to correct, but if anyone knows the details, please add or correct me.
-D'oh!
Old Jan 26, 2003 | 08:23 PM
webcarconnection
Hmm...the Greddy System is more interesting, don't you think!
Old Jan 26, 2003 | 09:24 PM
articfury's Avatar
articfury
Charter Member #55
web-
Actually, I like the design of the Stillen better. It should flow better. But we will just have to wait to see the numbers.
JD
Old Jan 27, 2003 | 01:22 PM
  #38
webcarconnection
web-
JD
I'm with you brother......
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
