K&N drop in filter HP increase?
Old Jan 20, 2003 | 06:00 PM
McDan's Avatar
McDan
Originally posted by zogan
why after it sat? B/C it cooled down?
Yes. Actually it sat before the first run without a fan blowing on it, heat soaking the engine bay. The tech even told me it would pick up approx 5-8 hp on the second run before it ran, due to a cooler engine.
Old Jan 21, 2003 | 11:06 AM
Canadian350Z's Avatar
Canadian350Z
Okay,
Don't flame me for asking this...
If a cooler engine can give us 5 to 8 more HP, why not develop a better engine cooling system to gain HP. What kind of temperature are we looking for? What if we run two radiators? four? Will the hood with the gills help in this regard? How much cooler does the engine need to be?
Just an idea....
Old Jan 22, 2003 | 05:07 PM
ScottC's Avatar
ScottC
Here is one more plus for the K&N - the attendants at the local oil change place wont hound you about changing your filter.
Old Jan 22, 2003 | 06:04 PM
zogan's Avatar
zogan
Good point
Old Jan 30, 2003 | 01:05 PM
bhobson333's Avatar
bhobson333
Default My results
I just dropped a K&N filter into my Z. My score:
Results: A
Application: C
I definitely noticed an improvement in throttle response, especially under heavy throttle. At greater than half-throttle I get more jump that I used to get. I like it!
However, I was disappointed in the filter itself. For $45 I expected a filter that fit properly into the air box, not jury-rigged with a couple of hokey stick-on foam shims and still not fitting nearly as good as the original. And it's not like this is some "specialty application" either, this is the same airbox & same filter as all or most recent Nissans & Infinitis!
Shame, K&N! You need to do better! (And trade in this crap for a properly fitting filter)
Old Jan 30, 2003 | 02:02 PM
6kLaunch's Avatar
6kLaunch
Originally posted by Canadian350Z
Okay,
Just an idea....
Or.... make the computer think the engine is cooler by modifying he signal from the coolent temp sensor. ...
Old Jan 30, 2003 | 02:11 PM
stx's Avatar
stx
Remove the thermostat if you live in a warmer climate. I don't need a heater and its hot enough that the engine seems to like it better with no thermostat.
Old Jan 30, 2003 | 02:34 PM
12SecZ's Avatar
12SecZ
Default Do they make a 160 stat for our cars?
Let me guess, it's 400 dollars right direct from Japan
Seriuos;y, I ran one in my LS1 and would like one in my Z.
Any links?
Old Jan 30, 2003 | 02:52 PM
stx's Avatar
stx
I haven't seen one yet. Hopefully they will make one.
Old Jan 31, 2003 | 08:40 AM
typerod's Avatar
typerod
wow 7 HP from K&N!! thats pretty good for just a filter change!
Old Jan 31, 2003 | 08:49 AM
del105's Avatar
del105
15 f125
I have a k&n filter and I definitly notice a difference to throttle response even if it is a very minor difference it is there I also have the injen pipe connected to my stock air box which may be causing the difference im feeling put them in at the same time.
Old Jan 31, 2003 | 09:07 AM
TalonZ's Avatar
TalonZ
Many people don't realize that completely removing the engine's thermostat can actually make the engine overheat. The thermostat acts as a constriction within the cooling system, even when it's open. The coolant needs to "dwell" (spend time) in the radiator to dispose of the heat it has picked up from the engine. If the coolant shoots through the radiator too quickly, no heat is transferred from the coolant to the atmosphere. The coolant gets hotter and hotter until the engine overheats.
I've heard that removing the thermocouple (the part that moves) from the thermostat so that nothing remains but the housing is enough restriction to retain the proper cooling. This supposedly also allows the engine to run cooler. I've never tried it.
Old Jan 31, 2003 | 11:43 AM
12SecZ's Avatar
12SecZ
Default Why not switch temps?
Like with a 160 or 180 if you are gonna go as far as remove the housing?
One thing is that it might effect the fans temp turn ons.
Hypertech's programmer let's you adjust your two fans for a 160 stat. We **really** need a programmer/flash/chip/ecu whatever for our car. I think right now it is the most needed mod for what we all are currently doing.
Plugs, stats, wheel size changes, intakes, exhausts, etc.
And I won't be paying 2k for it either!!!!
Anyone listening out there, give us import guys a break!
Even Supe Chips dropped there import line!! Booh!!!
Old Feb 1, 2003 | 06:05 AM
Zeromancer's Avatar
Zeromancer
That was freakin' great!!!!!
Old Feb 4, 2003 | 10:07 AM
ZINISTER's Avatar
ZINISTER
The bottom line with this car is that noone knows much yet about what will result in what, the strength of the block, etc. K&N's, generally speaking, will add horsepower, it's been proven. Until someone has tested the stock filter and the K&N (which it sounds like has been done, in this thread), everything's just guesses. Who's to say you'll get 1hp out of a K&N. Why not 2? That's totally a guess.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
