Test Pipe smell - still present in previously used pipes?
Old Feb 6, 2006 | 03:51 PM
titanjc's Avatar
titanjc
Default Test Pipe smell - still present in previously used pipes?
I purchased a set of used Helix non-resonated test pipes from a fellow forum member. I'm not sure exactly for how long, but they were installed on his car for some time.
Now I've read that when you first install test pipes, you will smell unburnt fuel quite prominently for several hundred miles. I'm wondering if this will still be present in test pipes that have already been used? Does the smell go away afer the ECU relearns proper A/F ratio, or is it something inside the new test pipes reacting to the exhaust gasses that causes the smell?
Old Feb 6, 2006 | 03:59 PM
southern_info's Avatar
southern_info
The test pipe smell never really goes away totally. Your stock cats are design to catch unburnt fuel and burn it up. Well now that you have test pipes which is basically a straight pipe. Your unburnt fuel doesn't get burnt and it runs through your test pipes into your exhaust system. It burns up the unburnt fuel constantly even after the old fuel is burnt up. Your going to have to deal with it when having test pipes or get high flow cats!
Old Feb 6, 2006 | 04:04 PM
titanjc's Avatar
titanjc
A lot of threads report that the smell almost went away after a few hundred miles of driving though.. or is it just the unburnt fuel killing the sense of smell of the drivers in the threads that I've seen?
Old Feb 6, 2006 | 04:11 PM
mgl's Avatar
mgl
they will still smell. its just a matter of getting use to it.
i have 5k miles on my res. test pipes and i really only notice the smell when i stand behind the car or get something outta the trunk.
Old Feb 6, 2006 | 04:12 PM
southern_info
At first you notice it big time from inside the car a little, with the windows down you can tell a little still, then if you stand behind your car you'll notice it alot more. To be honest I can't speak on others behave but at first you notice it then after I'll say a month you'll barely notice it. It will always be there and I've had my test pipes before X-Mas, so go figure!
Old Feb 6, 2006 | 04:13 PM
plumpzz's Avatar
plumpzz
My theory is that the car will adjust the AF ratio when you change your cats, but it wil take the computer a while to change it so that it isn't running as rich. So even if their used, the smell isn't from the test pipes burning in so to say, but its more from unburned fuel.
Old Feb 6, 2006 | 04:18 PM
titanjc's Avatar
titanjc
So how bad is the smell REALLY? I mean does it punch you in the nose when you turn the key, or is it kind of like hmm something smells a little funky, but you can't quite put your finger on it? How bad is it when say, you're sitting at a stoplight with the windows down? Windows up?
Just trying to get a feel for these things before I take the time to install them.
Old Feb 6, 2006 | 04:36 PM
Ztampa's Avatar
Ztampa
Depends which way the wind is blowing. If you're sitting at a light with the windows down and the wind is blowing just right, you definitely get a good dose. I never really mined the smell, but some people that ride in my car complain. If you put the A/C on recirculate w/ the windows up, you won't smell it.
Old Feb 6, 2006 | 07:08 PM
97supratt's Avatar
97supratt
It smells and also burns your eyes, lol.
Old Feb 6, 2006 | 09:25 PM
johnlotusboy's Avatar
johnlotusboy
The oil film on new pipes will burn off just like a new exhaust.
The unburnt fuel smell won't go a way PERIOD, the computer can't/won't "fix" the smell.
This is the facts!!!
Old Feb 6, 2006 | 09:29 PM
ZON's Avatar
ZON
It will never go away but Jimmy Cracked Corn and I Don't Give a Damn.
Old Feb 7, 2006 | 09:14 AM
CarlosZ's Avatar
CarlosZ
I have the same problem, I figure it would exit through the exhaust tips and not from underneath the car where I can smell. Maybe I have an exhaust leak?
Old Feb 7, 2006 | 10:10 AM
titanjc's Avatar
titanjc
Thanks for the description, that was very helpful!
Old Feb 7, 2006 | 10:40 AM
LODOSS's Avatar
LODOSS
my teg did'nt have a cat and it was not very pleasing.. girls don't like it for sure..
on a turbo car i notice even when catless the smell is not as bad..
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
