Am I wasting my time and money??
Old Feb 9, 2006 | 09:57 PM
bacalhau16's Avatar
bacalhau16
just try a couple bolt-ons and see what it gets u.
I'd say, pop charger, 5/16 spacer, and a set of megan test pipes. Total for everything is right around $500 give or take. If you put them on and you like it your good. If you dont and want to be a lot faster, well then save your money because only F/I can save you from here!
Old Feb 9, 2006 | 10:00 PM
MFAnello350's Avatar
MFAnello350
thanks man....good advice
Old Feb 10, 2006 | 01:01 AM
05 NISMO's Avatar
05 NISMO
Originally Posted by Bubble
Header: $500 installation cost: $300 = $800
Test pipe: $150- installation cost: $100 = $250
Spacer: $180 - installation cost: $50 = $230
Pulley: $200 - installation cost: $100 = $300
Unichip: $900 - included installation
Total: $2480
You're half way of Vortech or Turnonetic already. What is the reason you can't go F/I? cost? if that the case then save it bit more and go with F/I. If not then go for it.
well bubble you also have to put into considation with the install, and tunning it... either way your **** out of pocket.
Old Feb 10, 2006 | 02:48 PM
MFAnello350
so what do u think? spring is around the corner and i want to know what to do....help! S.0.S.
Old Feb 12, 2006 | 03:55 PM
MFAnello350
i was lookin to get test pipes soon....any suggestions on what to get? want sumthing good...i was thinking APS but not sure....
Old Feb 12, 2006 | 11:43 PM
ZON's Avatar
ZON
You have intake & exhaust already. You could probably do cams and ECU for just under 3K. With 3K that might be your best bet for gains. But I would recommend headers after that for best results. But which engine do you have? If you have rev-up 300hp VQ you can only do intake cams right now, in which case you should get the Nismo S tune intake cams.
Old Feb 13, 2006 | 04:00 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Cams? for what? First im pretty sure he had a certain budget and also i think going internal is the last thing he'd want to do. A MD plenum spacer, Labree or APS test pipes, and headers from either Crawford, DC Sports, or Strup. Keep in mind that any combination of parts they will put you in the 1100 to 1500 range but without installation. Personally i say nix the headers and put it to something more useful.
Old Feb 14, 2006 | 03:23 AM
MFAnello350
i want to keep it plain and simple....plenmium spacer,pulley,headers,chip,t.p. etc....nothing too big....
Old Feb 14, 2006 | 05:28 PM
Nismo 350z's Avatar
Nismo 350z
get a 5/16 spacer, UR crank puley, APS tp's, dc or strup headers and get an ECU reflah because you won't need a UTEC with those mods.
Old Feb 14, 2006 | 05:37 PM
bacalhau16's Avatar
bacalhau16
i agree with those mods fully. Pretty much exactly what i have or will be adding shorty.
Nismo 350z, those are good numbers before ur flash. What do u think u have now, about 275whp or so, and what do run in the 1/4?
Old Feb 14, 2006 | 08:06 PM
MFAnello350
does the Unorthodox Pulley set screw up ur engine at all? wanna know b4 i do stuff....i heard it messes the engine up....please help me out and inform me so i know b4 i do...
Old Feb 14, 2006 | 08:29 PM
bacalhau16's Avatar
bacalhau16
i dont think it messes up ur engine, as there are a lot of people on the forum using it. I believe when pulley's first came out for the Z, there was a lot of discussion about the pulley and its quality and perhaps throwing off the timing off the motor because it was too light or it would be mis-shaped or something.
Old Feb 14, 2006 | 08:53 PM
knight_white99's Avatar
knight_white99
If you want peace of mind, stay NA. I have done intake, plenum, exhaust, headers, test pipes, flywheel, pulley, cams and TS re-flash. Cheap? No, especially the cam install. Worth it? For me, living in AZ (where a turbo is just not in the cards due to summer heat), it was the only way to go (still a bit cheaper than FI if you can do some of the work yourself). The car is MUCH faster than stock. Worth it? I think so... the car is now a blast to drive. The engine spins up very quickly. A 3.9 gear might be my next mod...
Old Feb 14, 2006 | 09:01 PM
ZON's Avatar
ZON
He want's performance mods. He said he has $3000 budget right now. I gave him my opinion from my own experience. Cams and ECU piggyback like mine with a tune will do more for him & you than just simple bolt on's. Cam's isn't really going internal. If he don't want cam's then who cares, I don't.
Edit: Oh yeah and I mentioned cam's because I consider them to be bolt on's, expensive bolt on's, but bolt on's nun the less.
Old Feb 14, 2006 | 09:17 PM
MFAnello350
ok sounds good...sorry to sound liek a newb but what are the 3.9 gears? what do they do? never really looked into them,...did a search didnt see ne thing i could read up on that would help me understand it...
Old Feb 14, 2006 | 09:22 PM
ZON's Avatar
ZON
You have 3.5 stock Final Drive gears if you are a six speed. A 3.9 (FD) will lower your final drive ratio thus you will rev quicker. Your gears will not have as much speed, but you will be quicker. The Final Drive is in your rear differential.
Old Feb 14, 2006 | 09:27 PM
MFAnello350
well what if u have an automatic like me ???
Old Feb 14, 2006 | 09:33 PM
  #38
ZON's Avatar
ZON
Maybe even better result's, I'm not sure. You will definately get results you will feel and enjoy. Your Automatic has a 3.36 FD, even taller than the 6 speed's 3.5 ratio. A good mod for acceleration that you will exploit.
Central 20 has a 3.9 FD for about $500. I don't know how much install is.
Edit: You should know beforehand that this mod will lower your top speed. Not that you want to go 156 mph, I don't. But your overdrive rpm's will suffer when freeway cruising.
Old Feb 14, 2006 | 09:47 PM
  #39
ZON's Avatar
ZON
Here's a decent thread on 3.9 FD, MFAnello350. https://my350z.com/forum/engine-and-drivetrain/164866-350evo-3-9fd-install-questions.html
Old Feb 16, 2006 | 06:31 PM
  #40
MFAnello350
bump....
