Should I Reset The ECU
Old Feb 17, 2006 | 12:27 PM
pingbling23's Avatar
pingbling23
Default Should I Reset The ECU
I installed the motordyne spacer and i can feel a diffrence in power. Around 3500-4000 rpm i can feel like a slight hesitation in power and then the power picks up even more. i heard someone say theres felt like a v-tec so thats kinda how it feels. is this normal and i didnt unhook my battery for 24 hours to reset the ecu, i just unhooked it long enough for the install. should i unplug it for 24 hrs and reset the ecu. Thanx
Old Feb 17, 2006 | 05:35 PM
HoldThisForMe's Avatar
HoldThisForMe
If you are going to reset the ECU there is a much faster way...may not be as easy but you still retain all other settings ie..radio stations...Do a search cuz its insane to type it and i dont have much time to look up the site for ya...search for ECU Reset should give you some results...Ive always reset my ECU with a new install
Russ
Old Feb 18, 2006 | 06:21 AM
RP-350Z's Avatar
RP-350Z
Here is a link to the quicker way to reset your ECU.
https://my350z.com/forum/showthread....=THROTTLE+BODY
Old Feb 18, 2006 | 06:34 AM
pingbling23
Were getting a little snow so i just went ahead and disconnected the negative side of the battery. what is that about pumping the accelerator and brake to bleed out the ecu? appreciate the help.
Old Feb 18, 2006 | 09:56 AM
HoldThisForMe
It sounds complicated when you read it but its so easy to do..takes about 45ish seconds and ur done, the ECU is reset and off you go.
Old Feb 18, 2006 | 11:01 AM
Drive for for 200 miles. If you don't like the way the car performs, then you can try resetting the ECU. BTW resetting the ECU is not a cure-all.
Old Feb 18, 2006 | 05:30 PM
pingbling23
Since the spacer install i have around 230 miles on it and im not wanting to cure anything i love the diffrence in performance i have, i was just wanting to try it out to see if it makes any diffrence.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
