AAM Plenum Spacer problem!!
Old Feb 20, 2006 | 10:25 PM
plastiketa's Avatar
plastiketa
Default AAM Plenum Spacer problem!!
I installed the spacer without any issues but when I fired up the car, I had an air leak in the bottom, middle bolt. I did buy this used, by the way. I reinstalled it twice and torqued the bolts correctly, but the leaking persisted.
I have one theory: the washer w/ integrated O-rings were COMPLETELY worn out and need replacing. BUT, only the bottom, middle bolt was the problem, so why aren't the other bolts leaking??
Any Suggestions??
Old Feb 21, 2006 | 06:16 AM
Noah@AAM's Avatar
Noah@AAM
We can get you new gaskets, bolts and washers.
www.alteredatmosphere.com/
Old Feb 21, 2006 | 06:30 AM
It seems that Sport Z Magazine also had a problem installing the spacer.
Old Feb 21, 2006 | 10:19 AM
plastiketa's Avatar
plastiketa
so what happen? what mag issue?
Old Feb 23, 2006 | 10:58 AM
plastiketa's Avatar
plastiketa
bump! still need help!
Old Feb 25, 2006 | 08:18 AM
dynamic6er's Avatar
dynamic6er
Hi Plastiketa. I will send you some new o-ring washers overnight at no charge. Could you please pm me your address?
The o-rings are worn out or torn. New ones will fix it right away.
The Sport Z issue was due to the factory ECU going into a semi-limp mode.
Old Feb 25, 2006 | 02:01 PM
tmb's Avatar
tmb
Can you post any info from the article?
I have been emailing one of the fellows from AAM about their Spacer and they are very responsive.
I have not bought it yet but I cam close.
This will be the FIRST mod to my 2005 Z and so I am obviously nervous about doing this.
My Z is in the body shop right now thanks to some ****** who nailed the right front fender in a parking lot and I was parked in the BACK of the lot.
Course, they did not leave a note.
I figure my car deserves a present when I get it back
Old Feb 25, 2006 | 02:03 PM
350z9's Avatar
350z9
Default help
i got the skunk 2 spacer and when i put it in the car started up fine then all the sudden stalled what is the problem i warmed it up and didnt let it stall for a wile drove it around its fine but i have a realy rough ideal now any suggestions
Old Feb 25, 2006 | 02:15 PM
NIZZMO's Avatar
NIZZMO
Wow this has me re-thinking the spacer idea , any more members had spacer
issues ? I may just go with the Kinetix V4 upper plenum.
Old Feb 25, 2006 | 02:51 PM
RP-350Z's Avatar
RP-350Z
350z9,
99% of the time you have some kind of air leak. Try to listen for a leak. You might have to retorque the bolts. I have the 5/16" Motordyne spacer but I would imagine the Skunk2 one is similar. When you start your car does it idle or die on you?
Old Feb 27, 2006 | 08:18 AM
dynamic6er's Avatar
dynamic6er
Some cars have this issue some don't. If there is a leak then they all will, but if there is no leak then some cars need to relearn the idle for some reason. After a few starts and runs it clears up.
Old Feb 27, 2006 | 08:38 AM
ZRiCaN's Avatar
ZRiCaN
My SES hasnt cleared yet, and has been running for about a week, I had an audible leak but tightened down, car seems to be running fine but light still on
https://my350z.com/forum/engine-and-drivetrain/173856-d-ohh-and-solutions.html
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
