Got the Pop Charger Installed today
Old Mar 11, 2006 | 07:14 PM
deviljon's Avatar
deviljon
instead of using the screws, just use some double sided tape to hold the heat shield to the snorkle. that way, you dont have to put holes in the snorkle and it will hold up just fine.
Old Mar 11, 2006 | 07:18 PM
MR.OKKKK's Avatar
MR.OKKKK
it dont have to be new to whistle.. hehe.. but yes its true.. when its new its more noticeable... but dont forget to clean them... makes alot of difference too... had mine for about a year.. love it...
Old Mar 12, 2006 | 07:27 AM
AZNNBLK's Avatar
AZNNBLK
looks like the JWT pop charger is a good choice? i m still trying to decide which one to get... any recommendations? Thanks!
Old Mar 12, 2006 | 10:40 AM
Z_Driver's Avatar
Z_Driver
Master
JWT Popcharger- Great sound.
K & N Typhoon - However, doesn't have the nice sound. It about double the price. However, it is true cold air that you can add ram air to if you want to.
Old Mar 12, 2006 | 11:59 AM
deviljon's Avatar
deviljon
+1 on the popcharger
Old Mar 12, 2006 | 12:35 PM
jetspank's Avatar
jetspank
+2 on the Popcharger. Easy install, too.
Old Mar 12, 2006 | 04:43 PM
Rhoads's Avatar
Rhoads
Paint that heat shield! Why does JW make the heat shield that ugly gold... I painted mine black. Looks much better.
Old Mar 12, 2006 | 05:46 PM
Z_Driver's Avatar
Z_Driver
Master
That is a great idea !!!!
JWT used a alodine coating:
Alodine" is a non-anodic protective coating. Alodine {aka Iridite, aka Chromate Conversion} is a microscopic thin film commonly prescribed on aluminum to:
1. Provide an Excellent surface prep for paint aid in Corrosion Resistance
2. Impose desired Electrical 'Resistance' characteristics, and so is commonly
prescribed for Radio and Amplifier cabinets.
Bottom line is it is a cheap and good way to protect aluminum parts.
Old Mar 26, 2006 | 03:06 PM
AZNNBLK's Avatar
AZNNBLK
finally installed the jwt pop charger today.. thankz for the pics n tipz.. i m amazed at the sound of it combined with the nismo catz!
Old Mar 27, 2006 | 12:39 PM
Roggan's Avatar
Roggan
Ive had both a Popcharger setup (open cone filter on stock tubing) and now the K&N, and they sound pretty much identical. If one sounds better i would say the K&N because of the metallic resonance you get from the air box.
Prefer the looks of the K&N carbon fibre lid and the box that shields from hot engine air + it has the snorkle if you want cold air ram, im very pleased with it! Though like it has been said, its hard to beat the sound per $ that you get from the popcharger.
/Roger
Old Mar 27, 2006 | 09:14 PM
Cannysage's Avatar
Cannysage
My popcharger can whistle, 'mary had a little lamb'
_bit
Oct 2, 2015 07:49 AM
