Instructions For Test Pipe Installation!!
Old Mar 21, 2006 | 04:07 PM
jaslui119's Avatar
jaslui119
Default Instructions For Test Pipe Installation!!
Can anyone please give me instructions on how to install test pipes?
I tried searching it but couldnt find any info that would help.
I have a G35 coupe 6mt-dont know if installation will be different than 350z.
BUT PLZ HELP!!!!!
Old Mar 21, 2006 | 04:13 PM
zachcrosen's Avatar
zachcrosen
Its fairly simple.
-open beer bottle
-unbolt the OEM cats at the header and y-pipe (5 screws and/or nuts)
-unbolt from the cat support thing(1 screw)
-throw away 1st beer bottle and open a 2nd one
-unscrew O2 sensor making sure not to damage it
-reverse this for installing TP, except dont install the screw to the support thing. Only use the support if its part of the TP design or with a HFC design.
-throw away 2nd beer and open yet another one
The screws/nuts at the header side is a biotch to get to with a ratchet. A ratcheting wrench is highly recommended if I remember correctly.
Maybe this will help. Had to throw in a little humor!!
Old Mar 21, 2006 | 06:45 PM
showstoppertk's Avatar
showstoppertk
if you just do a search on "test pipe install" you should come up with numerous posts on the subject, however you may have to read through a lot of it. but here is some info to help.
Items needed
-ramps or jack stands
-wheel chocks
-anti-seize compound (to put on bolts for easy removal later)
- 7/8 or 22mm O2 wrench/socket (for O2 sensors) or crescent wrench
-20” socket extension
-socket elbow/joint
-new gaskets if the original ones are in poor condition (otherwise just clean them)
-14 mm wrench (for cat bolt nut)
-6 shims/washers for v-brace and rear cross-brace (to alleviate movement of cats when moving/bottoming out and rubbing)
-10 ss 10x20mm nuts
-10 ss 10 mm bolts
-10 ss 10 mm lock washers
-WD40 (to help loosen the bolts)
Hints
-may need to use a hammer/mallet to create space between heat shield and pipe
-to loosen the header to cat bolts you need to use your extensions and elbows and lower them from above the engine bay and have a friend beneath the car guide the socket to the bolt
Old Mar 21, 2006 | 07:30 PM
jaslui119's Avatar
jaslui119
Haha..Thanks Guys.>!
what are some tools that i need?
20" extention? can you elaborate on that? thanks!
Old Mar 21, 2006 | 10:48 PM
jaslui119's Avatar
jaslui119
Alrite...i just printed the info out...Thanks alot guys!!
Old Mar 22, 2006 | 10:41 AM
HockeyZ39's Avatar
HockeyZ39
Originally Posted by dave079
Its just a 20" extension you can buy for your socket to make it longer. You will need two of them to get it done right. I just went to Sears, used them, and returned them the next day.
Heres a pic of a 1/2" drive 20" extension:
http://www.sjdiscounttools.com/skt40163.html
Why would you need 2? I did my test pipe install from completely under the car. Was a HUGE pain in the a$$, and now I have an exhaust leak from the test pipes b/c I couldn’t get them tight enough. I am planning to take them off and put some exhaust sealer compound and going from the top of the engine to make sure there are no more leaks
Old Mar 22, 2006 | 02:53 PM
Mike Wazowski's Avatar
Mike Wazowski
If you have to ask questions like this you should not even be attempting to do this on your own.
Old Mar 22, 2006 | 03:43 PM
teh215's Avatar
teh215
I think that we should petition all vendors to supply a 6 pack with all purchases.
Old Mar 23, 2006 | 09:08 AM
HockeyZ39's Avatar
HockeyZ39
Because one wasnt long enough to be able to get that bolt that connects the test pipe to the top of the header. Trust me it makes it easier doing those top bolts from the top of the engine bay.
Can you get the bolts tight enough through two 20" extensions!? Seems like it would be very flimsy even with some one holding it from below.
Old Mar 23, 2006 | 11:47 AM
guitman32's Avatar
guitman32
To minimize the chance of exhaust leaks, use this product (the Ultra Copper) on the testpipe/HFC-header flange.
http://www.caswellplating.com/permat...ketmakers.html
(PERMATEX® ULTRA COPPER® Hi-Temp RTV Silicone Gasket Maker)
Old Mar 23, 2006 | 11:52 AM
HockeyZ39's Avatar
HockeyZ39
That is a gasket replacement? The wording leads me to think that. Or do you just throw in on each side of the gasket?
Old Mar 24, 2006 | 05:33 AM
HockeyZ39's Avatar
HockeyZ39
Guess I will be making a few trips to walmart (to get them and take them back!)
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
