Need help!!!! With Mrev
Old Mar 22, 2006 | 03:47 PM
Driver350Z's Avatar
Driver350Z
Default Need help!!!! With Mrev
Hey guys I just installed the Mrev on my 06 Z.
It is running extremly rough in the low RPM's. Is this the way everyone else's are running.
At idle it runs perfect. But when I start moving its really rough.
Please let me know if this is normal. Thanks
Old Mar 22, 2006 | 04:27 PM
SpeedRcr's Avatar
SpeedRcr
it sounds like you have a leak...check around the oil neck and double check all your bolts in your throttle body as well
Old Mar 22, 2006 | 04:38 PM
Driver350Z's Avatar
Driver350Z
Well after checking around my engine. I decided to loosen up my strut bar and found out that it was too close to the plenum.
It fixed the problem but I had to take off my strut bar. I used all the spacers and the washers but it just didnt fit. Is there a certain way im supossed to put it on or what?
Old Mar 22, 2006 | 05:10 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive installed 2 with no issues. Spacers go under the STB, not over the bracket...
Old Mar 22, 2006 | 07:49 PM
Driver350Z's Avatar
Driver350Z
Yeah I put them under the brackets but it didnt work for some reason.
Did you use washers? And did you have to adjust the tension on the bar?
Old Mar 22, 2006 | 08:37 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You can turn the tensioner bolt on the strut bar to optimize the clearance. Its an easy fix.
_koubie_
Sep 20, 2015 06:34 PM
torchkc
Sep 11, 2015 08:26 PM
