motordyne 5/16 spacer w/ ISO gasket review
Old May 16, 2006 | 02:29 PM
slackjaw's Avatar
slackjaw
So...I take it the hod is hitting the strut tower bar! thus causing the "buldge" in the hood. That doesn't sound good. Please elaborate.
Old May 16, 2006 | 02:33 PM
jwales's Avatar
jwales
There IS a little bulge from hood touching the strut tower bar on the driver's side but it is really very minimal. I think most of the people on this site, like myself, are perfectionists. However, unless I point it out, people can never tell.
Old May 16, 2006 | 03:05 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by jwales
I purchased the 5/16 ISO Thermal Spacer and I honestly have not noticed any difference in how hot my engine bay and upper plenum are after driving (they are still damn hot!). The power increase and the sound change, however, are instantly obvious.
As for DIY, the instructions on the MD website are top-notch and walk you through every step. I am a complete novice when it comes to cars and engine but I was able to do it with minimal cursing in an afternoon.
jwales,
I see you have the popcharger listed in your sig. If you havn't noticed a difference in plenum temperature after installation of the Iso Thermal, it is because the pop charger tends to draw in a significant amount of hot air from the engine compartment. And this air is typically air comming through the radiator.
The popcharger heat shields don't really seal too well.
As an experiment, you could temporarily install your stock air box (which is the best for drawing in cold air) and test plenum temperature against the popcharger.
One thing for sure, the plenum can never run cooler than the air flowing within it.
Try your stock air box. It will make a big difference. A difference in temperature that is easily felt.
Let me know what you find.
Thanks,
Tony
Old May 16, 2006 | 03:14 PM
jwales's Avatar
jwales
I will give that a try and see if it makes a difference.
Old May 19, 2006 | 07:19 AM
boma's Avatar
boma
Is there any way to install this without it hitting the hood? I thought the 5/16's was designed for clearance and the 3/4's was the one that needed the hood to be raised.
Old May 19, 2006 | 07:36 AM
Hydrazine's Avatar
Hydrazine
Yes.
It is rare that it ever touches the hood. If it does, most of the time it only needs adjustment of the strutbar tension.
Old May 19, 2006 | 07:49 AM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
Originally Posted by Hydrazine
Yes.
+1
one thing everyone who does the install should do is spend a little time tweaking the strut bar. tweaking here means more than just sitting in the garage with wrench. you actually need to tweak a little then drive the car to make sure you don't hear the strut hitting the upper plenum. then tweak more, etc. you should also put something like chalk or whatever on the strut bar when doing this. this will help you determine if the bar is actually touching the hood or plenum.
there is a sweet spot in most cases. it just might take some time to find it.
Old May 19, 2006 | 08:56 AM
Hydrazine's Avatar
Hydrazine
Haha! +1
And that is only if it your car has a tight tolerance stackup. Most can just bolt it on and drive off without having to do any further adjustment.
Old May 19, 2006 | 10:31 AM
SBT's Avatar
SBT
i dont feel that what is being said is convincing enough
somebody post a picture of the worst case scenario with how the hood bulges
hulkout
Apr 28, 2017 09:00 PM
_koubie_
Sep 20, 2015 06:34 PM
