Larger Throttle Body from another Nissan?
Old Apr 3, 2006 | 09:28 AM
Quamen's Avatar
Quamen
Default Larger Throttle Body from another Nissan?
I am just doing some research on things and I was wondering what problems you would run into using another throttle body that is larger from say a Q45. Aside from having to use a piggy back or something for fuel what problems would you run into. This is also assuming that the intake manifold and air intake are also larger to accomodate more airflow.
Would throttle response be lessoned?
Would you still be able to use the larger diameter piping and the stock MAF sensor as you do on the Injen and K&N intakes and just use the EMU to accomodate for the MAF not reading the accurate voltage due to diameter?
Thanks for all of your help ahead of time.
Old Apr 3, 2006 | 09:46 AM
captj3's Avatar
captj3
I looked at my FX 45 (03) the throttle body is the same as my Z. The part # on it is the same. I thought mine was bad so instead of buying 1 I was going to switch them. The only difference I saw was a spacer between the throttle body and the intake manifold. I hope this helps you.
Old Apr 3, 2006 | 11:05 AM
MustGoFastR's Avatar
MustGoFastR
Crawford offers a bored out throttle body and their cast plenum has a larger opening to take advantage of it. Not sure what gains it has or if it requires special tuning.
Old Apr 3, 2006 | 12:34 PM
Quamen's Avatar
Quamen
What about something from like an armada or titan. I know that these have a bit bigger bore. I am looking at getting bigger than a bored out TB so I would have to upgrade to a different vehicles TB. Also will velocity or anything be affected by the large TB?
Old Apr 3, 2006 | 02:03 PM
97supratt's Avatar
97supratt
Subscribing...
Old Apr 3, 2006 | 02:26 PM
John@Victory's Avatar
John@Victory
subscribing as well
Old Apr 3, 2006 | 03:30 PM
blasian's Avatar
blasian
I believe Crawford mentioned something in another thread about wanting to try the TB from Q45 but they needed to actually get one.
It was the thread they posted videos of the dual TB setup.
Old Apr 3, 2006 | 07:43 PM
Quamen's Avatar
Quamen
That is actually what inspired this thread is their post. I looked at the Nissan website and it seems that most of their vehicles come with the drive by wire throttle body like the Z so with the exception of having to prolly splice the wires and trick the stock MAF I really dont see that many other problems. hopefully someone like Sharif or Charles gives some input.
Old Apr 3, 2006 | 08:11 PM
Quamen's Avatar
Quamen
Just doing some research and here is what I have found.
First off the Nissan Titan believe it or not basically has the same size throttle body as our Z (70mm). There is one that I found that they bored out to 75mm which would be nice. However, I also read that the problem that people were having with bored out TB's from companies such as Proflow and 350evo is that the TPS (throttle positioning system) does not work as well. Can anyone elaborate on how this is affected and how the TPS would be affected with a larger TB?
Also, someone stated that the Q45 (VK45 engine?) used a 90mm TB in another thread. This would be really nice. Can anyone confirm the TB size.
Also, addressing the TPS, could a unit such as the UTEC take care of this issue through idle adjustment or something else?
Old Apr 3, 2006 | 08:13 PM
Quamen's Avatar
Quamen
Just confirmed that the Q45 does have a 90mm throttle body but I dont know if it is drive-by-wire
Old Apr 3, 2006 | 08:20 PM
Quamen's Avatar
Quamen
Just reading a bit more. I dont thing that a Q45 TB is drive by wire and another problem is that NA just wont benefit because you lose air velocity and therefore may not flow as much air based on vaccuum. However with a ram air intake you could flow more I am sure. You would just sacrafice performance at lower speeds and if you didnt have air ducted into the intake to increase air velocity to maximize flow.
Old Apr 3, 2006 | 08:32 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I know that the JIC drift car has the Q45 TB on it, but they had to elminate the drive by wire setup. I saw it in person and it was friggin huge.
Old Apr 4, 2006 | 05:40 AM
atlsupdawg#2's Avatar
atlsupdawg#2
Don't know about newer model Q45's but the older models do use 90mm throttle bodies but aren't DBW. Supra guys, at one point, were switching over to these with much success but that's a different breed compared to NA. Good luck..
Old Apr 4, 2006 | 07:30 AM
97supratt's Avatar
97supratt
Very true, until veilside came out with the manifold and huge 100mm TB setup.
Old Apr 4, 2006 | 09:23 AM
Quamen's Avatar
Quamen
I believe that is the 90mm throttle body someone I know is putting in their 2JZ powered ford probe.
Old Apr 4, 2006 | 09:28 AM
97supratt's Avatar
97supratt
Ford Probe? You gotta be kidding me. How?
Old Apr 5, 2006 | 05:12 AM
meatbag's Avatar
meatbag
I was just searching around and i found that the 2005 Q45 has a DBW system but i dont know anything specific on the throttle body other then that.
Old Apr 5, 2006 | 06:05 AM
Quamen's Avatar
Quamen
Yeah a ford probe baby. Same company that blew up my Z.
Old Apr 5, 2006 | 08:53 AM
zachcrosen's Avatar
zachcrosen
Interested as well...
Old Apr 5, 2006 | 09:17 AM
Clapton9286's Avatar
Clapton9286
People shouldn't modify probes..
subscribing.
