Drilled hole in throttle plate! UH OH!!! =(
Old Apr 13, 2006 | 09:50 PM
G352NV's Avatar
G352NV
Im thinking about doing this.
Old Apr 13, 2006 | 10:54 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I love ghetto mods.
One small hole can save you a trip to the dealer to raise RPM at idle lol...
Old Apr 14, 2006 | 08:28 AM
overZealous1's Avatar
overZealous1
dealer would not raise the idle on my car, alot of them won't. they said they didn't even know how to do it. not really considered a ghetto mod if it saves ya $500 from technosquare and does the same thing.
i prefer to call it an educated mod to get away from people soaking ya for dough, lol
Old Apr 14, 2006 | 09:11 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Old Apr 14, 2006 | 11:10 AM
JhayRCruz's Avatar
JhayRCruz
damn, my dealer was happy enough to raise my idle after my cams install.. If anyone who lives in Bergen County, NJ, Fisher Nissan is a friendly...
uve got big ***** to actually drill....
Old Apr 14, 2006 | 12:07 PM
Julian@MRC's Avatar
Julian@MRC
I forsee a mass hysteria of people with F'd up Throttle Bodies looking for New ones soon.
I think Ill run out and buy the rest of the TB's in stock at my local Nissan
Old Apr 14, 2006 | 12:41 PM
Zmego1985's Avatar
Zmego1985
I dont have a clue how you are going to fix that. This car has problems with parts as it is. Your ecu must be going nuts lol. My solution would to try to get a different butterfly plate from companys that rebore the original ones. Im sure they would have the factopry piece, because after all they change it. Ask Doug at crawford Z what you can do.
Best of luck Glen
Old Apr 14, 2006 | 08:10 PM
benitoz's Avatar
benitoz
I have a 2005 z so the dealer cant change the idle. So many people freak out when people like me try things like this... if you have ever been into any cars like 300zx tt's ect ect. there are so many tricks and tips around because of people like me. I am aware that i could cause damage to my tb. THere are tb's on ebay for 25 bucks.... all the time. I have done this before on tb's when i turbo non turbo cars and it has worked fine... But wasnt shure with the drive by wire. Its not cheap sending the ecu to ts. to have the idle higher. I have just been clicking my ac or heat on and it bumps the idle up high enough that it never dies. I am also at 5700 feet. there is less air up here. Im going to open her hole back up tomarow and give her some air and see what happens.
Old Apr 14, 2006 | 08:12 PM
Gman2004's Avatar
Gman2004
benitoz,
Will you take a picutre of the tb and the hole? I am interested in the ghetto mod.
Old Apr 14, 2006 | 08:24 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
this is some funny ish....
lets give our plenums a vacuum leak....
im actually drilling mine right now!!!
Old Apr 14, 2006 | 09:16 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
LOL I agree with you that it is an educated mod, but come on... that **** is still ghetto
Old Apr 14, 2006 | 09:42 PM
benitoz's Avatar
benitoz
well this post kept me from sleeping... I re-drilled the hole and the idle is at about 900 I can rev high from idle and let off and it drops back down and idles smooooth. hmm ok now i can go spend 600 twords 550cc injectors and cams =) Oh so ghetto but oh so cheep. (free)
Old Apr 14, 2006 | 09:51 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Do you guys know you can raise your idle by 110rpm's via the Cipher tool? Much better solution if thats all you need to raise it....
Old Apr 15, 2006 | 01:35 AM
Gman2004's Avatar
Gman2004
I've already paid for the TS flash and had the idle raised, but since the FCON my idle goes between good to bad depending on my driving conditions.
Is there anywhere in particular that you drill the hole?
Old Apr 15, 2006 | 03:03 AM
Z350Lover's Avatar
Z350Lover
subscribing...
cheers,
richie
Old Apr 15, 2006 | 03:35 AM
overZealous1
wow!! did you all hear this! it actually works! can't wait for a year from now, half the Z/G's will be driving with holes in the throttle plate!!!
i still love being a pioneer, even if ya'll call it ghetto.
Old Apr 15, 2006 | 03:53 AM
overZealous1
the only thing that is being simulated is more metered air into the motor. thats all the ecu is trying to calculate for. the ecu just thinks the throttle is opened to about 1-2%.
under what conditions is your idle bad? hard braking? just getting out of boost? fluctuate while at a rest with foot on brake?
the best part about this mod is that it still allows the ecu to control the idle. if anyone has taken the throttle motor apart and inspected how it works, there is about a 10 degree area outside of the normal dbw that is supposed to control idle. it is nearly impossible to bump the idle by manually controlling the throttle plate. the only way is to trick the ecu. letting more air into the motor accomplishes this.
thanks benitoz, for proving my point on your car. glad to see it is working good for you now.
Old Apr 15, 2006 | 04:01 AM
  #38
overZealous1
i got my drill in hand i bump your idle for $499. hahahahaha
honestly, i would not tell anyone to do things i have not already done and gotten positive results
Old Apr 15, 2006 | 05:08 AM
  #39
Gman2004's Avatar
Gman2004
when hard braking and clutch is depressed quickly just before breaking (car stalls). If I hit the brakes with the car in gear it won't stall, but when I come to a stop it jump from 500 to 1500 and back to 500 rpms. If I blip the throttle a couple of times it catches it self and stays at 800-900 rpms. It also jump at idle with the a/c on. As soon as I turn it off it stabilizes again.
Old Apr 15, 2006 | 05:14 AM
  #40
booger's Avatar
booger
Where on the plate did you drill the hole ? Out side edge ? middle ?
