Nismo S - Tune vs Borla?? Pros and Cons
Old Apr 22, 2006 | 06:30 AM
steveiZdaman's Avatar
steveiZdaman
Default Nismo S - Tune vs Borla?? Pros and Cons
deciding which exhaust to go with but i am confused...they both sound good but can u guys that have either the nismo or the borla chirp in here...thanks
Old Apr 22, 2006 | 08:24 AM
Z CRUZN's Avatar
Z CRUZN
Just a few general comments here.....
I've heard both exhausts as well......without headers & HFC, both seem similar in sound...the Borla a little quieter than the Nismo at high RPM's. With headers & HFC (Crawford's at least) the Nismo becomes quite a bit louder than the Borla at WOT. I have the Nismo with the Crawford's and love it.... but I can understand some people wanting the Borla for a little more refined/ civilized noise level with headers & HFC.
As for install, the Nismo is a simple "bolt-off...bolt-on" undertaking - all connections are factory locations. With the Borla, there are numerous pieces involved (Borla is a true-dual system) - want to make sure the pieces all line up to prevent rattles, rubbing, etc. Some have even had the pieces spot-welded after install to make sure the pieces don't shift/move. After installing headers & HFC, my Nismo had to be moved and shimmed a bit to prevent rattles as well - no biggie on either system.
As for performance, most quality exhausts perform within 2-6 HP, or there abouts, of each other. You'll enjoy either system
Old Apr 22, 2006 | 09:00 AM
I recommend that you
a. Set a budget.
b. Decide what configuration you want. Single. Dual. One or two mufflers. Y-pipe?
c. Shop for catback exhaust systems which meets your budget and selection criteria.
d. Pick your favorite.
Old Apr 22, 2006 | 09:52 AM
TheLastSpartan's Avatar
TheLastSpartan
go with the nismo if you wanna keep the VQ purr
i love my nismo (used to have topspeed)
Old Apr 22, 2006 | 03:58 PM
steveiZdaman
thank you that was very helpful...down the road i will most likely do the HFC
and being the nismo is bolt on i think i am going with that....me and my friend are going to tackle this one...since the borla isnt bolt right on that means i have to bring it to a shop.
Old Apr 22, 2006 | 04:44 PM
Beeker's Avatar
Beeker
You could install the Borla yourself. It just takes a lot more time. I wouldn't attempt to install the Borla without a lift and a lot of patience. The Nismo will be MUCH easier to install.
If you can, try to hear each system for yourself. I wouldn't decide based just on install time.
Old Apr 23, 2006 | 06:02 AM
steveiZdaman
i dont think i can drive my car up on ramps b/c of the greddy front lip...if anything im going to have to jack it up
Old Apr 23, 2006 | 06:20 AM
techcontrol's Avatar
techcontrol
I would go with the nismo. I had the Borla TD for about a year and got tired of it and went the nismo. I too had to adjust the Borla Y pipes when I did the HFCs and then again with the headers. Never again will I use a slip-fit system. GO NISMO!
Old Apr 23, 2006 | 06:50 AM
jovasi's Avatar
jovasi
I also have the Nismo exhaust & Crawford cats. I have been nothing but pleased with the set up. The sound is absolutely amazing, very exotic.
Borla makes a nice exhaust, but too many pieces to worry about coming loose or leaking.
Good luck with your decision.
Old Apr 23, 2006 | 09:43 AM
ZlleH's Avatar
ZlleH
The Borla Y pipe? You must be talking about the old Borla exhaust, not the Borla TD cat-back which does not have a y pipe.
As for the Borla TD cat-back, the shop said the quailty of the exhaust were great. they put the exhaust on in less then 2 hours. It's been 13,000km now with no rattles and leaks.
I recently got HFC installed at the same shop, they didn't need to adjust the Borla, they took like 30 minutes to install the HFC. It's now 2,000km with the new HFC and no rattles or leaks.
The Borla sounds great before, but now with the HFC, it's an exotic sounding beast. I've had tons of comments that my exhaust setup sounds like a Ferrari.
But I definately recommend the Nismo, the less 350Z out there with the same sound as mine, the better
Here is some stats from Sport Z magazine to help you decide on what you want:
PEAK HP:
1. Borla 8.2
2. Stillen 8.1
3. Injen 7.6
4. Nismo 6.3
5. 5Zigen -3.4
PEAK Torque:
1. Stillen 7.3
2. Injen 5.1
3. Nismo 4.5
4. Borla 2.7
5. 5Zigen 0.2
Old Apr 23, 2006 | 10:37 AM
techcontrol
PEAK HP:
1. Borla 8.2
2. Stillen 8.1
3. Injen 7.6
4. Nismo 6.3
5. 5Zigen -3.4
PEAK Torque:
1. Stillen 7.3
2. Injen 5.1
3. Nismo 4.5
4. Borla 2.7
5. 5Zigen 0.2
Yes, I'm refering the Borla TD, The individual pipes form a 'Y' so I call it like I see it. You are right, about the power figures, I did lose some when I switched to the nismo. The Borla TD was still too quiet no matter what. Also, the lack of flex joints and the pain of removing the exhaust when doing transmission work makes the Borla a true PITA. Either way, it's all personal choice.
Old Apr 23, 2006 | 11:05 AM
steveiZdaman
thanks a lot guys....i am going to go with the nismo s tune....
anyone know the cheapest place to order it?
i know performance nissan had it for $880 i think on sale but with the whole credit card hacking thing their site is getting done over...
any other good sites to order this? i also need the installation hardware which is another $100 or so.
thanks
Old Apr 24, 2006 | 01:50 PM
cox's Avatar
cox
thanks
Concpetzperformance.com.... i have bought my Nismo from them.... great dealer.....
You dont need to buy the hardware.... it comes in the package with the exhaust....
Old Apr 24, 2006 | 01:51 PM
cox's Avatar
cox
thanks
....Conceptzperformance.com.... i have bought my Nismo from them.... great dealer.....great price and low shipping cost (i'm from Italy )....
Old Apr 24, 2006 | 02:40 PM
ANXIOUZ's Avatar
ANXIOUZ
Both are great exhausts. If you can afford the Nismo and don't mind the price tag, get it.
Old Apr 24, 2006 | 03:20 PM
steveiZdaman
i will check it out...thanks
Old Apr 24, 2006 | 05:00 PM
Gering's Avatar
Gering
I have the NISMO and it sounds Great!
Old Apr 24, 2006 | 05:49 PM
steveiZdaman
yea the sound is amazing...i heard a few clips of it...and wen i was on vacation in miami...some guy had it on his Z and it sounded awesome in person
Old Apr 24, 2006 | 05:52 PM
steveiZdaman
that conceptzperformance has it for a decent price with all the hardware....how is that site in the customer service department?
any other sites that have it for a good price...less then $1g?
Old Apr 24, 2006 | 06:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
we are under $1k and are in NY, so you can pick it up - shipping that thing gets pricey
http://z1auto.com/prodmore.asp?model...ust&prodid=308
