AAM Spacer Question.......Need Help
Old May 2, 2006 | 05:13 AM
yoichi's Avatar
yoichi
Default AAM Spacer Question.......Need Help
I jusy installed the AAM Angled Spacer. The car is noticably louder and everything seems to be all right while driving but at idle, it seems to bog once in a while. Is this normal or would restting the ECU help??? Thanx guys
Old May 2, 2006 | 07:58 AM
g_torphins's Avatar
g_torphins
Sounds like a leak.
Check/retighten all the bolts on the top of the plenum.
Mine loosened off a LOT after I installed my AAM.
George
Old May 2, 2006 | 10:33 AM
Goofy1477's Avatar
Goofy1477
The same thing happened with mine, so I tightened the bolts, but it still happens. I checked for leaks, but could not feel any. I have no clue whats going on.
Old May 4, 2006 | 07:47 AM
Noah@AAM's Avatar
Noah@AAM
tighten the bolts.....drive the car...then shut her off...let it sit a minute or two...restart and that should clear up the issue
Old May 4, 2006 | 08:43 AM
Goofy1477's Avatar
Goofy1477
Tried that. It still does not solve the problem. Personally I am so sick of the problem, I am about to take off the plenum spacer and get a crawford plenum.
Old May 4, 2006 | 12:48 PM
Mr_pharmD's Avatar
Mr_pharmD
what do u mean by bog at idle? I thought bog was when your car is reving but the car isnt really moving and it feels like your car has hit the rev limiter and the car is jerking.
U might want to check for leaks. Tighten the bolts with a torque wrench to about 100lbs on the outside and 60lbs on the inside. Also make sure the rubber piece surrounding the oil cap is clear and not under the top of the plenum.
Old May 4, 2006 | 12:58 PM
Z_Monzter's Avatar
Z_Monzter
Change the middle botton bolt for a short one and I bet that will solve your leak and your idle issue!
Old May 5, 2006 | 08:40 AM
Goofy1477's Avatar
Goofy1477
at idle (when the car is stopped at a light etc.) the car revs between 500 and 1200 rmps, bogging down and up. It can't keep a steady idle. This only happens once in a while.
Old May 11, 2006 | 05:59 AM
ChazzReinhold's Avatar
ChazzReinhold
dont tighten the spacer down with a torgue wrench. Those bolts break and strip easily. Instructions with my spacer said HAND TIGHTEN ONLY!
Old May 11, 2006 | 06:43 AM
Road Warrior's Avatar
Road Warrior
thats what i did but you also have to buy a new strut bar if thats what you decide to do
personally, i would check out the mrev2...seems like a good bang for the buck and you get to keep everything else stock
Old May 11, 2006 | 06:57 AM
pawnmarty's Avatar
pawnmarty
Default aam spacer
make sure you didnt catch that little rubber funnel shaped thing that surrounds the oil filler. if you dont pull it back with your finger when you place the spacer on the lower plenum it will be pinched between the spacer and the lower plenum. i did this but noticed before i started the car,but not before all bolts were tightened(naturally) hope it helps!
Old May 11, 2006 | 07:02 AM
Goofy1477's Avatar
Goofy1477
Originally Posted by William@Altered
this sounds to me like a leak somewhere in the system - did you check the gasket to make sure it's installed properly? you may have all the bolts tightened to the proper torque but sometimes (i have done it) the gasket is not placed properly (around the back of the plenum) and it causes a leak -
check that and let me know -
I dont want you to be unhappy with your product to the point that you sell it for another one -
William,
I actually got my spacer installed at your shop, so I would not know if the gasket is installed properly. At first within a week, the bolts were so loose they were about to fall out. So I tightened them. but I am still getting problems. Anyways I spoke to someone at the shop and next week I will come by to get it looked at. Just sucks because gas is so expensive and you all are so far away.
Old May 11, 2006 | 07:16 AM
Road Warrior
you would definately know it if this happened...the sound is very very loud
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Stevo Z
Oct 3, 2015 09:14 PM
