Should I put a light coat of oil on the pop charger?
Old May 4, 2006 | 08:56 PM
whoopazz1's Avatar
whoopazz1
Default Should I put a light coat of oil on the pop charger?
Before I install it, should I do anthing to it. I thought you're sopposed to coat it with something to keep the dust from entering. Or should I just install it normaly....?
Thx.
Old May 4, 2006 | 08:57 PM
Z BOY's Avatar
Z BOY
if its blue, its oiled. too much oil is a bad thing. less is best.
Old May 5, 2006 | 08:09 AM
andy2434's Avatar
andy2434
The PC comes pre-oiled from the manufacturer. You will not need to oil it again until you clean it.
Old May 5, 2006 | 08:27 AM
3FITTTY's Avatar
3FITTTY
How often should you clean em? Mine is no longer blue..
Old May 5, 2006 | 03:34 PM
whoopazz1's Avatar
whoopazz1
Awsome, thx for the 411 boyz.
Old May 5, 2006 | 05:49 PM
fairlady350z33's Avatar
fairlady350z33
normally you should clean after 50,000 miles according to K&N. but under extreme conditions you should clean more often. Check out your filter, if it seems as the intake is sucking harder than normal, then get a filtercharger kit from k&N and clean that sucker.
Ted
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
