Popcharger vs CAI
Old May 5, 2006 | 05:18 PM
sja177's Avatar
sja177
Default Popcharger vs CAI
So I have seen tons of proof that the popcharger is better than the CAI's out there, but I just dont understand why.
Why should hot air be better than cold? I know that air velocity has a lot to do with it, and the shorter the velocity route the better top end hp. (Atleast with manifolds like the plenum)
Is there anyway around this?
What about a CAI that has larger diameter piping and a bigger filter to change the velocity?
Theres gotta be someway to do this...
Old May 5, 2006 | 05:21 PM
NissanZfan's Avatar
NissanZfan
Old May 5, 2006 | 05:46 PM
fairlady350z33's Avatar
fairlady350z33
there should be blood coming out of that horse!!! go with whatever you like, seriously. intakes don't differ that much in the amount of HP they give you, go with price, looks, or ease of cleaning. the HP won't differ much.
Old May 5, 2006 | 05:53 PM
GMZ's Avatar
GMZ
Heres my thoughts since I am about to go clean mine up a little bit The Popcharger uses the stock intake tube which is made out of plastic, but all the CAI's well most of them have metal tubes. At startup they may be "cold" but once you drive around those metal pipes heat up alot, thus heating the air charge going into the engine, but the stock plastic tube doesnt absorb so much heat. The CAI's position of the filter may give it cooler air than the Popcharger but that difference may be negated when combined with the hot tube. So in other words theyre all about the same Im gonna go play with the car now.
Old May 5, 2006 | 06:33 PM
sja177's Avatar
sja177
Originally Posted by NissanZfan
Did you even read what I wrote?
If its been beaten to death tell me smart guy, the answer to my question (which you didnt even read) Why does the popcharger produce much better results than a CAI? Give me your scienfitic explanation and not a "well the pipe is plastic."
I really dont feel like running a system that has hotter air than stock, thats just plain stupid, but the cai sucks.
Theres people working on innovations for the plenum, why not intake?
Old May 5, 2006 | 06:38 PM
sja177's Avatar
sja177
https://my350z.com/forum/drag/185964-best-time-13-77-s-100-8-mph.html
3mph is the difference between an m3 and 350z
Old May 5, 2006 | 07:25 PM
NissanZfan's Avatar
NissanZfan
No im not a smart guy, it’s called a search button. I don’t think it’s been proven that a pop charger produces better results, especially when the power is so minimal (that is the argument that has been beat to death). I got it because its cheap 109vs.250+ easy to clean and seems to have the same results as all the rest.
Old May 5, 2006 | 08:45 PM
Armitage's Avatar
Armitage
Awhile ago, the Popcharger in a shootout dyno'd 6.5rwhp, which beat out all other intakes it was tested against (I think AEM and Nismo?).
Old thread:
https://my350z.com/forum/showthread....ntake+Shootout
Old May 5, 2006 | 08:54 PM
Z BOY's Avatar
Z BOY
i think the long tube is too restrictive, air-volume-wise.
Old May 5, 2006 | 09:36 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's harder to suck air through a long tube compared to a short tube.
The stock air box is already a "CAI."
The JWT might be able to flow a little better, but it is not a CAI.
My $0.02 is keep the stock air box, that is my plan.
Old May 6, 2006 | 08:37 AM
sja177's Avatar
sja177
Well what if I were to build my own CAI but use larger diameter piping, would that make a difference?
Old May 6, 2006 | 08:40 AM
sja177's Avatar
sja177
Its called a search button, pop charger gains much better high end power, which usually cant be seen on a dyno, look at the thread I posted. The guy trapped 3mph just by changing out the cai to a short ram.
Old May 6, 2006 | 09:16 AM
Z BOY's Avatar
Z BOY
go for it, but i believe many others have tried. check the intake forum.
Old May 6, 2006 | 10:04 AM
sja177's Avatar
sja177
Thx for the help Z boy
Old May 6, 2006 | 10:18 AM
Nexx's Avatar
Nexx
from reading about this topic over and over again
advantages popcharger
1. cheap
2. sounds great, very mean at wot
3. nice gains for such a minor mod
4. dont have to worry about sucking in water
advantages cai
.... crickets.... crickets....
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
z33z_nutz
Sep 23, 2015 07:22 PM
juang20
Intake
Sep 7, 2015 05:37 PM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
