Polished MREV2
Old May 16, 2006 | 10:32 PM
OCG35Coupe's Avatar
OCG35Coupe
Default Polished MREV2
What do you guys think? I might even coat the bottom of the collector with swain tech to keep the heat from the engine away.
Old May 16, 2006 | 10:54 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
ooooooh so shiny... mine's supposta get in today.. we'll see.. it's been 2 weeks since i ordered it!!!
Old May 16, 2006 | 11:12 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
wow nice and shiny. how much hp/tq would it give.
Old May 16, 2006 | 11:23 PM
OCG35Coupe's Avatar
OCG35Coupe
I dunno, Tony from Motordyne said it cant hurt,that it would do nothing but good, so i figured what the hell, why not..
Old May 16, 2006 | 11:28 PM
taurran's Avatar
taurran
Looks good. Now someone just needs to try this on the same car with the original MREV2 and then the polished version. Did you get the inside of your upper plenum polished as well?
Old May 17, 2006 | 07:35 AM
mchong75's Avatar
mchong75
How much does it cost to polish it?
I'm still waiting on mine.
Old May 17, 2006 | 07:41 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Holy Krapola!
Now thats a polished plenum!
Old May 17, 2006 | 08:34 AM
Strife350z's Avatar
Strife350z
HOT HOT HOT!
was that a DIY project? Or did you send it out to get polished?
Old May 17, 2006 | 08:57 AM
3hree5ive0ero
Retired Admin
+1 but it's supposed to come in today so we'll see.. btw you missed a good meet.. you should check the TX forums once in a while.. we have meets lined up.. from now on, we'll be having a meet every 2 weeks. PM me if you want more info on it
Old May 17, 2006 | 09:00 AM
OCG35Coupe's Avatar
OCG35Coupe
Originally Posted by Strife350z
HOT HOT HOT!
Sent it out to get polished. It was like $150.
Old May 17, 2006 | 03:18 PM
OCG35Coupe's Avatar
OCG35Coupe
Originally Posted by Hydrazine
Holy Krapola!
Tony. I had the whole length of the runners polished too, but now im reading this:
From The Science of Horsepower: Porting & Matching Heads & Manifolds, Larry Carley, Underhood Service, November 2001
http://www.babcox.com/editorial/us/us110128.htm
"As for polishing, Mondello said a smooth finish is great for exhaust ports, but a rougher finish flows better on the intake side. He recommends using 300- or 400-grit paper followed by a Cross Buff for polishing exhaust ports, and 50- or 60-grit paper for the intake ports. A slightly rough surface texture in the intake ports and intake manifold runners creates a boundary layer of air that keeps the rest of the air column flowing smoothly and quickly through the port."
Does that mean i should not have polished the whole length of the runners? Maybe i should have just left the inside of the runners how they were?? Is what Mondello is talking about "boundry layer turbulance" talked about underneath??
http://www.coat-this.com/automotive/..._manifolds.asp
The inside of the runners in an intake manifold can also be coated. A single layer of a dry film lubricating coating (DFLC-402, DFLC-404 or DFLC-401), also known as ?fluid retaining coatings? treates the fuel/air mix as it passes through an intake manifold on a carbureted engine as a "fluid in motion" and can reduce fuel drop-out by creating boundry layer turbulence. For maximum gain, first apply a thermal barrier (TCD-201) to the inside of a runner, then a dry film (DFLC-404) over it to not only create the boundary layer turbulence, but further reduce the amount of heat that does enter the fuel/air mix.
So would a layer of Dry Film coated inside the runners be beneficial? Help Help Help lol.
Old May 17, 2006 | 05:40 PM
Hydrazine's Avatar
Hydrazine
I don't know about the coatings or what they will do. But, I do feel a little skeptical of coating claims in general though.
But like I said previously, Rickdogg and I pre/post dyno installed a polish of the runners and it had little effect. It only produced a 4 HP blip about 500 PRM wide, convieniently at the HP peak.
You can search for his post for more information.
Old May 19, 2006 | 07:58 PM
OCG35Coupe's Avatar
OCG35Coupe
I cant find it! He has over 4000 posts and has started 215 threads...Did he start the thread? Do you remember who did? Do you remember any words that were used in the title of the thread?
Old May 19, 2006 | 08:17 PM
plumpzz's Avatar
plumpzz
If you can imagine a water flowing through a tube, the friction on the surface of the inside of the tube cause the water to be very turbulant on the surface, and the center obey's the rules of laminar flow while being constricted by a layer of turbulent water. Thats what a "boundry level of air" is.
I'm pretty sceptikal (spelling...lol) of that claim. I'm also skeptical that polishing would make a huge difference, unless you're nitrous.
Old May 19, 2006 | 08:39 PM
3hree5ive0ero
Retired Admin
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
