SES question
Old May 24, 2006 | 02:20 PM
tommym's Avatar
tommym
Default SES question
First of all, I have searched on this. Just wondering if anyone with high flow cats has had the SES light go off? I know with test pipes it has happened. Yesterday the SES light came on, but it has been a couple of months since I have modded. The only thing that has happened, is that I ran over a plastic bag, and it was stuck to my Y-pipe. I had the light cleared, but it came back this morning. No decrease in power, and nothing seems wrong.
Thanks.
Old May 24, 2006 | 02:45 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You need to go get the code. You can't know a priori that the hfc caused the SES light.
Old May 24, 2006 | 02:56 PM
tommym's Avatar
tommym
I should have mentioned that. When I had it cleared, he said it was an 02 sensor code. I should have gotten the number when he did it.
Old May 24, 2006 | 03:35 PM
Cannysage's Avatar
Cannysage
it can happen to HF cats as well as TP. My resonated TP isn't suppose to throw a light (according the the manufact. site) but it did. I used a non fouler technique and it went away. If you're sure it's the cats, do it.
Old May 27, 2006 | 03:49 PM
tommym's Avatar
tommym
Ok, so I did the non fouler technique Thursday, and the SES light came back on today. I am not sure what to try next. I think I do have a slight exhaust leak, but that wouldn't have anything to do with the SES light, would it?
Old May 28, 2006 | 08:14 AM
G3.5T's Avatar
G3.5T
How are you clearing the codes? If you are doing the pedal method or clearing with a obd2 scanner try the overnight 12 hr neg. battery terminal disconnect. That is the only method that truely re-set my ecu.
Old May 29, 2006 | 08:25 AM
tommym's Avatar
tommym
I cleared the codes with an obd2 scanner, and the technosquare method. haven't tried the battery disconnect yet. I did get the code. It shows 2, but read the same thing. P2A03 02 Bank Sensor 1 range/performance. Has anyone had this code, or can someone tell me what it is?
Thanks.
Tommy
Old Jun 6, 2006 | 05:50 PM
tommym's Avatar
tommym
anyone? It just came on again today after a week.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
