Crawford Plenum Install Question
Old Jun 27, 2006 | 08:01 AM
JasiJ's Avatar
JasiJ
Default Crawford Plenum Install Question
Ok this is going to be a Noob question, but. I searched and didn't see any post on this. I have also read and re-read the instructions for the Crawford Plenum and numerous posts.
My question is should the bolts on the plenum be torque to a specific in/lbs or ft/lbs? I know when doing the spacers it seems that they do, but I have not see this in the instructions with the full Plenum.
I just received mine and I am anxious to install but want to do it right.
So if anyone knows OR has some nice tips/tricks to the install I would be greatly appreciative.
Old Jun 27, 2006 | 09:29 AM
Beeker's Avatar
Beeker
I would call Crawford and find out what they recommend. I highly recommend you use a torque wrench. It is very easy to over tighten and snap the plenum bolts. Motordyne recommends 100 "INCH" lbs for the outer bolts and 60 "INCH" lbs for the inner bolts. You could use those figures. I'm sure Crawford would recommend about the same.
Old Jun 27, 2006 | 09:37 AM
JasiJ's Avatar
JasiJ
Actualy was on the phone with Doug as you wrote this. He answered my question. Thanx....
Old Jun 27, 2006 | 12:35 PM
03zsmith25's Avatar
03zsmith25
why do people ask these questions??? use common sense... X ft*lb is 12 times as much as X in*lb. There can only be one or the other
Old Jun 27, 2006 | 01:06 PM
JasiJ's Avatar
JasiJ
My question was what IS the tourque?? I completly got the notion that 12'' = 1FT but I did not know the original tourqe spec either in IN or FT.
Thank you though for your help...
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
