Ultimate Racing HFC Install & OEM Comparison
Old Nov 18, 2006 | 08:26 AM
  #41
DanielW's Avatar
DanielW
what do you mean by slop?
Old Nov 18, 2006 | 05:49 PM
  #42
m1james@bellsou's Avatar
m1james@bellsou
The amount of movement you have in the mounting flange before tightening. It's the difference in the bolt diameter (slightly smaller) vs. the hole in the flange (slightly bigger than bolt).
If you loosen then hold the cat in the desired position then re-torque it may provide the space you need....hopefully
Old Nov 19, 2006 | 11:42 AM
  #43
DanielW's Avatar
DanielW
so this worked for you? and it was the bolt on the mounting bracket?
Old Nov 19, 2006 | 08:02 PM
  #44
m1james@bellsou
Was referring to the flange that mounts the cat to the header. The bracket that spans both cats and bolts to the transmission housing gets torqued last and isn't going to help you with a clearance problem.
Old Nov 20, 2006 | 07:37 AM
  #45
DanielW's Avatar
DanielW
oh ok do you have a picture of that by chance?
Old Nov 20, 2006 | 02:13 PM
  #46
m1james@bellsou
Look at the pic in the first post on this subject. The second picture (top row from left) shows the OEM and UR inlet end of the cat. What I'm refering to is where the studs go through the holes in the picture. You need to jiggle it to allow as much room vs. the floor panel on the drivers side as possible. The passenger side has a whole lot of room so clearance shouldn't be a problem.
Fixxxercask
Nov 9, 2015 11:10 AM
codek
Sep 28, 2015 03:03 AM
SharX59
Sep 27, 2015 09:23 AM
