Ebay Intakes
Old May 4, 2010 | 01:11 PM
Carlos8183's Avatar
Carlos8183
Default Ebay Intake?
So I was looking trough ebay and i saw an Intake for $45
http://cgi.ebay.com/ebaymotors/BCP-0...Q5fAccessories
http://cgi.ebay.com/ebaymotors/2004-...Q5fAccessories
what do you guys think? waste of money or maybe some potential in it?
what if i change the filter for a K&N filter would I still get same benefits?
thanks for the help.
Old May 4, 2010 | 01:39 PM
Ruthless18x's Avatar
Ruthless18x
NO.
Old May 4, 2010 | 01:42 PM
jduet's Avatar
jduet
Please no
Old May 4, 2010 | 02:03 PM
davidmcc's Avatar
davidmcc
*facepalm*
Old May 4, 2010 | 02:09 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
^^^ why is it so bad?
It is just piping; do you honestly think that a $300 CAI will be better if the piping has the same diameter and is routed the same?
What makes one piece of aluminium piping flow better than the other?
You can't just say NO, you have to support the statement..
When I did my first turbo kit (a while ago now) I bougth one of those just so I don't have to fabricate the piping from IC to TB. It was a pefect fit, and I had no issues with it even under 6psi of boost. It saved me a bunch of time, as the filter sits right where my IC outlet was.
The piping before the MAF sensor was the proper diameter (same as MAF sensor housing) This is important for he MAF metering.
EDIT:
I even have some pictures:
Insted of the air filter I continued to the FMIC:
OP, go for it.
Nexx's Avatar
Nexx
well, im sure an ebay intake can do exactly what a popcharger can do:
1. heat soak
2. provide no added power
3. make sure you car sound cool
Old May 4, 2010 | 02:24 PM
Waiz's Avatar
Waiz
2nd one plus K&N intake would not be bad at all.
You could probably add a JWT filter with this setup as well.
Old May 4, 2010 | 02:28 PM
Boosted Performance
1. heat soak
Or this $303 intake: http://cgi.ebay.com/ebaymotors/AEM-C...Q5fAccessories
OP, if you are going to get one, get the first one you linked. At lest the air filter will sit behind the bumper and get some "cooler" air in.
Old May 4, 2010 | 02:30 PM
huyrua's Avatar
huyrua
OP you should ask this guy,
https://my350z.com/forum/maintenance...ir-intake.html
Old May 4, 2010 | 05:04 PM
Carlos8183's Avatar
Carlos8183
EDIT:
OP, go for it.
That's what I was thinking a pipe is a pipe. the only difference in my opinion would be changing the filters and save $200.
Thanks for the feedback everyone
Old May 4, 2010 | 05:09 PM
terrasmak's Avatar
1. heat soak
Actually JWT doesn't do anything for heat soak, some people who really don't know what heat soak is say it does. What it actually does is draw how air from the eng compartment while at a standstill, but once the car is moving its only 8 to 10 degree's hotter with better airflow than stock. JWT does provide gains! The dif betweent he ebay crap and the JWT is the heat shield, without the heatshield you draw 100 degree hotter air than normal at all times. You need the heatshield!!!
Old May 4, 2010 | 05:29 PM
MODDEDZ's Avatar
MODDEDZ
Originally Posted by huyrua
Sounds about right... It's not just material, it's about know how. Save yourself some trouble.
Old May 4, 2010 | 05:43 PM
350Z400rwhp's Avatar
350Z400rwhp
I don't see a problem with it. May not look good over time as it may discolor because of it being a cheaper material but I bet the gains would be the same as a JWT, well if there are any gains with the JWT that is.
Old May 4, 2010 | 05:45 PM
Finally. A thread about eBay intakes. I have been looking forward to this.
Old May 5, 2010 | 04:05 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
OP...bought one w/ K an N for somewhere around 80-90 cannot remember...pipe is pipe and I was at one point a certified welder before college.
That being said, email them to find out diameters and thickness of material or you may get real flimsy piping which is in fact $hit piping.
Due dilligence....and you will have (0) probs
Old May 5, 2010 | 05:04 PM
davidmcc's Avatar
davidmcc
This has been brought up SO MANY times already
...thats why
btw, you're right, there's probably no difference between that and the more expensive version. Something to consider though is that design (ie. AEM) has been actually proven in the past to lose power.
OP. If you really want one of those and have a Rev-up I will trade you the AEM CAI that came on my car when I bought it for your stock airbox. ...I'M SERIOUS, you just have to pay to ship both and the airbox has to be from a Rev-up.
Old May 5, 2010 | 06:13 PM
  #38
MODDEDZ's Avatar
MODDEDZ
There's a reason why it's only sold on ebay.
Old May 30, 2010 | 05:29 PM
  #39
sevensinz79's Avatar
sevensinz79
piping is piping bro... just try to stay away from eBay headers and exhaust, known to have leaks from weak welds
good luck and you have my thumbs up
Old May 30, 2010 | 06:25 PM
  #40
GBoger's Avatar
GBoger
stick with stock airbox with kn drop in filter
