car runs weird after installing air intake
Old May 1, 2010 | 05:04 PM
slimsol's Avatar
slimsol
Default car runs weird after installing air intake
Guys,
I installed an after market short ram air intake in my 350z. After installation i noticed the car runs rough. specially on highway speed. I have to press gas pedal more to keep up the speed. Also i noticed that the shift has become jerky too. Should i stick to stock air box?
Old May 1, 2010 | 05:40 PM
temoku's Avatar
temoku
did u install everything correctly, any leaks? MAF installed properly?
Old May 1, 2010 | 06:01 PM
slimsol's Avatar
slimsol
Yes. I checked for all leaks. MAF was installed properly. I dont get throttle response as good as stock and car jerks at cruising speed
Old May 1, 2010 | 07:23 PM
RandyK1's Avatar
RandyK1
Reset the ECU!!!
Old May 1, 2010 | 07:45 PM
The intake is not suitable for your Z and will adversely effect performance.
Old May 1, 2010 | 07:47 PM
slimsol's Avatar
slimsol
I think you are right. My z didnt like this antigen. I am installing stock airbox back tomorrow. I hope it takes care of everything
Old May 1, 2010 | 08:32 PM
huyrua's Avatar
huyrua
^^^Sarcasm^^^
Old May 1, 2010 | 11:26 PM
dirtbikr's Avatar
dirtbikr
so you installed an intake, took davidv's sarcasm, gave up, and never even reset the ecu to let the car learn a little bit?
YOU =
Old May 2, 2010 | 03:58 AM
slimsol's Avatar
slimsol
YOU =
I unplugged the battery wire during installation. Doesnt it reset ECU? Car was revving up quickly but i felt it was moving slowly compared to stock intake. Engine was roaring like it was getting too much air but wasnt producing any power.
Old May 2, 2010 | 06:31 AM
huyrua's Avatar
huyrua
Did you install your MAF sensor correctly? Double check all your connections. Did you left finger/grease marks on the sensor? Post some pics? Pm me if you still having problems. It's not your intake that is causing the problem.
Old May 2, 2010 | 07:44 AM
08NismoZ's Avatar
08NismoZ
I hate to admit this but I had the intake on the driver's side of my HR motor flipped around. The MAF will only go in one way, but since the pipe was backwards so was the MAF sensor and the car ran exactly the way you're describing. I would try taking the tube off and flipping it around.
Old May 2, 2010 | 08:05 AM
Zazz93's Avatar
Zazz93
Guys,
What type of intake was it?
Old May 2, 2010 | 01:30 PM
slimsol's Avatar
slimsol
I reinstalled stock air box and car runs like champ. I guess there was nothing wrong with aftermarket air intake but after installing air intake i lost little bit of low end torque and engine revved high all the time. I prefer to have low end torque so i will stick to stock for now
Old May 2, 2010 | 01:33 PM
slimsol's Avatar
slimsol
Yes i installed MAF correctly but it was at different angle than stock.
I bought it off ebay it was POS brand
Old May 2, 2010 | 01:36 PM
jduet's Avatar
jduet
There's the problem
Old May 3, 2010 | 06:03 AM
slimsol's Avatar
slimsol
Back to stock
Old Jun 17, 2010 | 03:37 PM
biznut's Avatar
biznut
Did that solve the problem?
Old Jun 25, 2010 | 02:45 AM
Synjn's Avatar
Synjn
You never tried reseting the ECU and let it learn a bit? Sheeesh!
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
