JWT Charger and battery
Old Jul 20, 2006 | 10:21 PM
dkorr's Avatar
dkorr
Default JWT Charger and battery
RE/ before I install the JWTcharger
I read a few threads saying I'm suppose to disconnect the battery for 24hrs, pump the brakes several times, and idle for 10 mins after install, if CEL comes on go into OBD mode, or just drive it as is and let the car 'learn' from the adjust MAF. What is the proper way of installing? because the manual from JWT mentioned nothing about disconnecting battery, CEL, stalling at 90mph+-neutral, or OBD? Any ideas?
Old Jul 20, 2006 | 10:45 PM
blasian's Avatar
blasian
I didn't even d/c my battery when I installed *shrugs*
I had no problems.
Old Jul 20, 2006 | 11:05 PM
3FITTTY's Avatar
3FITTTY
i just installed it, didnt do any of that other bs..
Old Jul 21, 2006 | 11:53 AM
Mike Wazowski's Avatar
Mike Wazowski
as long as your key is not in the ignition there really is no need to worry about a CEL. Most of the people that got a CEL failed to realize that they had their key in the ignition (listening to the radio or something) and disconnected the MAF sensor plug.
As long as the car is OFF all you have to do is install the JWT and make sure everything is plugged back in and put together before starting the car.
Old Jul 21, 2006 | 12:04 PM
dkorr's Avatar
dkorr
thanks! that certainly clears it up.
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
_bit
Oct 2, 2015 07:49 AM
