SKUNK2 INSTALLATION HELP PLZ ( Silicone NEEDED ??)
Old Aug 10, 2006 | 10:48 PM
andonni's Avatar
andonni
Exclamation SKUNK2 INSTALLATION HELP PLZ ( Silicone NEEDED ??)
I just got it ( skunk2 spacer ) from my friend, but he lost the instruction, i look around on the website, i found on people putting on Silicone sealant, do i need Silicone sealant, where i can get it ? what kind Silicone i need ? thanks thanks
and plus .. anyone has complete kits of picture or link for website ? like showing all the bolts and stuff ?
thanks guys
Old Aug 10, 2006 | 10:49 PM
zz350zz's Avatar
zz350zz
motordyne aam
Old Aug 10, 2006 | 10:53 PM
andonni's Avatar
andonni
thanks for replying so fast
Old Aug 10, 2006 | 10:58 PM
Blue_Streek's Avatar
Blue_Streek
yeah just get a silicone sealant. do you have all the longer bolts? you will need all of them i got the spacer and it took about 1 hour to put on. make sure the car is cold so you dont break any bolts. there are 2 coolnat lines you need to disconnect. they are on the back of the plenum, and the strut bar will only fit if you add 2 washers and adjust the bar to the outer most extent,
tommy
Old Aug 10, 2006 | 11:06 PM
andonni's Avatar
andonni
i did check the aam and motordyne 's website .. i dont see them using the silicone sealant. . .
Old Aug 10, 2006 | 11:12 PM
Blue_Streek
yeah cause they provide 2 gaskets. the skunk2 instructions advise you using sealant. what i did was use the stock gasket on the bottom and a sealant on the top. no problems at all.
and i have had if for about 17k.
tommy
Old Aug 11, 2006 | 01:37 AM
andonni's Avatar
andonni
Blue Streek
thanks ... but what kind 2 gaskets ? the gasket for bolt or plenum?
Old Aug 11, 2006 | 06:47 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Your plenum already has one gasket between the upper and lower. You need to get one more from the dealer, it's a big one shaped just like the plenum spacer but with a bunch of stuff in the middle, trim out the stuff in the middle so it looks just like your spacer and you are good to go (or use RTV goop).
Chris
Old Aug 11, 2006 | 09:23 AM
no name's Avatar
no name
You may want to trim the hood where it hits the plenum too.
Old Aug 11, 2006 | 04:55 PM
andonni's Avatar
andonni
RTV goop ? sealant ? where i can get it ? do i need it ?
where i can get those gasket? skunk2 website ?
Old Aug 11, 2006 | 05:22 PM
no name's Avatar
no name
I used High-temp red RTV silicone gasket maker on the top and bottom because of the imperfections of the spacer. You can find it at Autozone, Pepboys, etc.
Old Aug 11, 2006 | 07:40 PM
andonni's Avatar
andonni
No name ..
how to trim the hood or plenum ? i dont really wanna plenum to hit my hood, i heard from my friend he used double sides tape... it melted it ..
thanks
andonni
Old Aug 11, 2006 | 09:06 PM
no name's Avatar
no name
Ok, get the rtv, get it installed, leave the strut bar off, and leave it sit overnight so the rtv can dry. Take it for a drive and check the hood and plenum for rubbing. Drill a hole and trim hood brace as necessary with some tin snips. Or I've seen people just leave it rubbing but I wouldn't do that.
Old Aug 12, 2006 | 02:24 AM
andonni's Avatar
andonni
thanks very much..
right now .. i am just not quite sure did he give enough bolts and gasket.. cause all i see, just long screws .. that's all ... but when i go onto skunk2 website, there are a lots stuffs, .. dont know what to do now .. i think i will post the pic of what i got for him .. and then ask for opinion ... thanks hope you will check the picture for me and tell me if i have enough bolts and gasket and etc...
andonni
Old Aug 12, 2006 | 02:44 AM
andonni's Avatar
andonni
anybody has instruction from skunk2 listing parts ? what's included with skunk2 spacer ???
i found one pic from www.i-m-racing.com ( just screws )
http://www.i-m-racing.com/skinpl5vqsp3.html
i found from skunk2 website , there are more stuff than what showing on i-m-racing.com 's picture
Old Aug 12, 2006 | 07:23 AM
Blue_Streek
you need everything from the SKUNK2 website. the longer bolts and the spacers and the washers.
tommy
Old Aug 12, 2006 | 07:30 AM
rpacman's Avatar
rpacman
http://www.*********.com/zwiki/Skunk2_Plenum_Spacer
Here's a write up I found. Hope this helps
-Rudy
Old Aug 12, 2006 | 07:32 AM
rpacman's Avatar
rpacman
ok nevamind... i guess it's a bad name....
Old Aug 12, 2006 | 03:56 PM
andonni's Avatar
andonni
yeah.. the link is not working ~
so.. the correct bolts and spacer is from skunk2 website right? not the one on i-m-racing.com ??
BEBO'S ZEE
Jun 7, 2016 07:48 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
