installed test pipes, now check engine light on....
Old Aug 21, 2006 | 09:30 AM
arodbrs's Avatar
arodbrs
Default installed test pipes, now check engine light on....
i need help, please how can i reset my ecu or get the check engine light removed.........................
Old Aug 21, 2006 | 09:40 AM
FastIntentions's Avatar
FastIntentions
Fast Intentions
you need what is called spark plug non-foulers. Part # 42002 of you help section in your local hardware store.
Old Aug 21, 2006 | 09:41 AM
blasian's Avatar
blasian
Originally Posted by Blue_Z
make sure you do it exactly as it says. you'll need a stopwatch.
I've done it plenty of times when my loaner ECU wasn't fully recognized by my car so it would go into "limp mode" every 35 miles.
Here's my summary of the reset instructions from TS's page
1. Turn the key to ACC, start stopwatch at the same exact time
2. At 00:03 seconds press the accel pedal in and out 5 times and stop just before you reach 00:08
3. Do nothing until 00:16, at 00:16 press the accel pedal down.
4. Let go of pedal at 00:26
5. Press again at 00:36
(Check engine light should start blinking from a slow blink to a fast blink by now)
6. Let go at 00:46
7. Press again at 00:56
8. Let go at 01:06
9. Turn off car
10. Restart Car, CEL should be gone/ECU is now reset
From another board but you can get the exact procedures from Technosquare's website.
Old Aug 21, 2006 | 10:34 AM
Of course you get a SES light. You replaced the catalytic converters with pipe.
Old Aug 21, 2006 | 01:18 PM
Zexy's Avatar
Zexy
If you don't have the resources or means to do the Non fouler fix i sell them pre drilled.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
