Plenum Spacers
Old Sep 3, 2006 | 12:03 AM
Sholmes555's Avatar
Sholmes555
Default Plenum Spacers
Hey guys, new to this forum, nice to meet you all! Have an 06 stock BASE. Looking to get a JWT popcharger (if i can find one cheap enough) and supplement that with a plenum spacer. Not sure what to get, I found this one by AAM @ http://www.alteredatmosphere.com/mm5..._Code=350Z_ENG
but some have said it's no good. They suggested Motordyne Spacers, 5/16" or 1/2". I've been told the half inch requires me to remove my factory strut bar and get another one, but that's a bit of money I'm not sure i wanna spend just yet (unless again...I find one for cheap). Therefore, i ask you guys if there's a NOTICEABLY huge difference b/w the 5/16" and the 1/2" ? thanks so much for helping! any general feedback on this would also rock!
Old Sep 3, 2006 | 12:06 AM
Sholmes555's Avatar
Sholmes555
on that, anyone have a dyno chart with JUST a plenum (namely this brand) and/or just a popcharger? send a pic! thanks
Old Sep 3, 2006 | 12:11 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Welcome to the forums... please use the search function before creating new threads as this topic is very popular and has been discussed a lot.
If you search I guarantee you'll find dyno sheets of plenum mods and more info than you ever imagined.
Old Sep 3, 2006 | 01:02 AM
Sholmes555's Avatar
Sholmes555
mc350z, i'm sorry what do you mean that the 06 model doesn't need the spacer? is the design that different from the 03-05 where the spacer won't do much or anything at all? thanks
Old Sep 3, 2006 | 01:12 AM
Z BOY's Avatar
Z BOY
yes, follow wired's advice (use search function, titles-only option), and you will learn everything you need to know. you probably have the "rev-up" engine, which is different from the non-rev and responds to mods differently. happy searching!
Old Sep 3, 2006 | 01:24 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
If you have a 06 stick, you have the revup motor with the short runners on the lower plenum. If this is the case, your best bet is the mrev2.
If you have an 06 auto, you have the same motor as the 03-05 have with the longer plenum runners. If this is the case, your best bet is 5/16 spacer.
Chris
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
