Exhaust Leaks Water...?
Old Sep 3, 2006 | 09:56 PM
drifter23's Avatar
drifter23
Default Exhaust Leaks Water...?
Just wanted to know if this is normal. If water drips at the midpipe and exhaust on startup. But, goes away when the car is warmed up.
Old Sep 3, 2006 | 10:00 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Basically an exhaust leak. It's just the condesation coming through. Have it all tightened down.
Rick
Old Sep 4, 2006 | 11:00 AM
drifter23's Avatar
drifter23
Thanks for the info.
Old Sep 4, 2006 | 11:10 AM
kpiskin's Avatar
kpiskin
I got some in mine from a lot of rain. Just the angle of the Nismo tips I guess. It'll eventually vaporize if that's all it is. Just go for a nice long ride, that's all I needed.
Old Sep 4, 2006 | 09:27 PM
ISMSOLUTIONS
That's not what it is...
Every exhaust produces water as the car warms up...it's science. If you see it coming from a clamp or a weld - that seal is not good. Chances are you will see the drip from the tailpipe or it will evaporate before it gets there.
Rick
Old Sep 4, 2006 | 09:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
hydrocarbons + air = CO2 + water (plus byproducts i.e. NOx, CO, carbon nanoparticles, etc)
Old Sep 5, 2006 | 02:44 AM
kpiskin's Avatar
kpiskin
Rick
We had a big storm pass through and that's the only time I've had the issue. Since then no water dripping.
Old Oct 8, 2006 | 02:10 AM
chishifu's Avatar
chishifu
on the same subject, I'm getting an exhaust leak at the mid-pipe y-pipe joint with water dripping. I've tried tightening everything down but it just won't work. I am thinking of just using a liquid sealant thingy? or should I take it to a shop. Thanks
ChiShi
Old Oct 8, 2006 | 06:38 AM
undrgnd's Avatar
undrgnd
ChiShi
Do nothing. Unless it is a major leak that you can feel and hear, leave it alone, especially if you've already torqued it down. Any muffler shop will tell you that. The corrosion products in the water will eventually seal it up. My JIC Y-pipe to Amuse midpipe connection dripped water for about 2k miles. It is now sealed.
Old Oct 8, 2006 | 07:49 AM
ISMSOLUTIONS
ChiShi
Other than ignoring it, you can always have those connections converted to flanges. It's not that expensive and much easier to take the system apart for servicing reasons.
Just make sure the flanges welded from the inside and spot welded on the outside for added strength.
Rick
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
Justin100
Nov 29, 2015 03:58 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Li1ag
Sep 28, 2015 02:07 PM
