Motordyne MREV2 & 5/16 PLENUM SPACER
Old Sep 6, 2006 | 01:02 PM
q8z's Avatar
q8z
Default Motordyne MREV2 & 5/16 PLENUM SPACER
i just installed 5/16 plenum spacer on my z ....
looking for more mods for my Z, i found the MREV2.
"When used with or without a spacer or aftermarket plenum, this modified lower collector will make substantial power gains. Multiple independent test show when used with a 5/16" spacer on the REVUP engine, the combination will add a "minimum" of 15+ HP and 18+ TQ in the upper midrange."
is there any draw backs if i both install 5/16 plenum spacer and MREV2..
does it take long to install the MREV2
finally do u guys recommend it
one more thing i have been reading bout the UNORTHODOX crank pulley..... interesting if it increases HP without drawbacks to the Z, is the UNORTHODOX recommended or not.
Old Sep 6, 2006 | 01:07 PM
Mazinger Z's Avatar
Mazinger Z
^I'm going to install my 5/16 + Mrev2 this week, hopefully it's as good as ppl say it is~
Old Sep 6, 2006 | 01:08 PM
xjongsangx80's Avatar
xjongsangx80
Your engine will sound like a V-8.. Trust me.
Old Sep 6, 2006 | 01:10 PM
Nexx's Avatar
Nexx
from what ive read, the if you have a rev-up adding the mrev2 will be a instant success without a tune. for the standard 287hp motor, if you add an mrev2, a tune is highly recommended to get he most out of the mod.
Old Sep 6, 2006 | 01:22 PM
Sr. Panza's Avatar
Sr. Panza
That's probably my next mod. I had most of the breathing mods except for the mrev2 and the spacer. I just dropped my car off at Street Image here in So. Cal. I'm getting some brake goodies! Installed
Old Sep 6, 2006 | 02:12 PM
q8z's Avatar
q8z
Default d
next week i am going to order the MREV2....
i just hope everything goes as i want and i hope the car doesnt need to be re tunned..
sounds like V8 engine. u sure
Old Sep 6, 2006 | 02:20 PM
GMZ's Avatar
GMZ
The MREV is the real deal! Ask Zincognito how his is, we put the MREV into hs car and it was a huge difference, added the 5/16" spacer on top of that and it was even more! Really its worthwhile, best mods out there imo.
Old Sep 6, 2006 | 03:54 PM
davidf's Avatar
davidf
But if you can only do one, then do the MREV2 over the plenum, it should give you better HP. Plenum is good but MREV2 is better.
Old Sep 6, 2006 | 04:02 PM
Mazinger Z's Avatar
Mazinger Z
****, I bought an Mrev2 from a member on this board...also bought a non-revup plenum for him for exchange...shipped it to me, and it was broken! Dunno what I should do...
Old Sep 6, 2006 | 04:28 PM
kourosH's Avatar
kourosH
mynismo.com always
Old Sep 6, 2006 | 07:32 PM
q8z's Avatar
q8z
real quick question, does it take a long time to instal the MREV2..
the plenum spacer took around 25 mins .
Old Sep 7, 2006 | 12:54 AM
Armitage's Avatar
Armitage
How was a plenum broken? Isn't it a solid piece of metal? Do you mean you bought a broken spacer?
Old Sep 9, 2006 | 11:54 AM
Mazinger Z's Avatar
Mazinger Z
I think it was broken during shipment, but he's in the process of refunding me so...looks like shipping co. dropped it, broke into 3 pieces...
Old Sep 9, 2006 | 03:17 PM
Mathys's Avatar
Mathys
Does the mrev2 change something to the height of the whole plenum? As I want to keep my CF strut bar which will work just fine with a 5/16" spacer...
Old Sep 9, 2006 | 03:23 PM
plumpzz's Avatar
plumpzz
MREV is what goes right underneath teh spacer. Its held down by 6 bolts, on top of the 500 that holds down the top plenum half. It'll take you 30 minutes if it took you 25 minutes to put on the spacer
Old Sep 9, 2006 | 04:07 PM
LMG_35C's Avatar
LMG_35C
No change to height, just velocity
Old Sep 9, 2006 | 05:34 PM
Ztalker's Avatar
Ztalker
i've had my UR pulley installed for two years and i think it's one of the best bang for the buck out there....just make sure the crank pulley bolt is torqued to spec, the install is pretty straight forward with the right tool. You'll feel improvement in your throttle response.
Old Sep 9, 2006 | 05:39 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
For what it's worth...
These mods have been on my car for a long time now, the ECU has had plenty of time to compensate, and I still need tuning. See my thread in Engine, Drivetrain forum about my progress with Cipher.
They are good mods and make real power, but more power is to be had from tuning HANDS DOWN.
Old Sep 17, 2006 | 05:23 PM
q8z's Avatar
q8z
Default Wired
SO... LET ME GET THINGS STRAIGHT HERE..
MY 04 350Z (MT) IS NOT A REVUP ENGINE....
Does that mean a plenum spacer is good enough for it.
I have been doing researches and it shows that MREV2 isnt much of a gain on a NONREV UP ENGINE (which is my car)
Is that right?
Old Sep 18, 2006 | 04:46 PM
SSG 350R6's Avatar
SSG 350R6
what is a revup engine? I came from the turbocharged DSM world and familiar with tuning. But I'm still trying to figure out what an mrev2 and spacer is, though I have a good idea. I don't own a 350z yet, but I'm highly considering it over an M3. I've been doing a lot of research on everything 350z so dump some more knowledge on me.
