Should I remove my popcharger
Old Oct 1, 2006 | 08:06 AM
Marbleshade's Avatar
Marbleshade
Originally Posted by CUxtopher
um, why not leave it? The v2 bumper should convert your poopcharger to a cai. It has a duct the pushes air to the hole in the front where the varis air duct feeds.
They should be compatible.
Still trying to decide if this was a spelling error or a very clever joke.
I, for one, recommend that every instance on this board of the word "popcharger" should be changed to CUxtopher's unique spelling of said word.
Old Oct 2, 2006 | 08:40 AM
driftk1d's Avatar
driftk1d
id just keep it..no point in taking it out and wasting the money you spent on it...and it sounds AWESOME
Old Oct 2, 2006 | 08:58 AM
Zlayer's Avatar
Zlayer
Originally Posted by jreiter
For what it's worth, I've done a decent amount temperature testing with my Popcharger. My findings matched up with what another person found and posted about quite a long time ago. (I forget who it was who did the initial testing.) I used an OBD scan tool to note the intake temperature (as reported by the car's computer) in various conditions. The results basically went like this:
At 35+ mph, the intake temp was about 5-10 degrees higher than outside ambient temp. This was also true when the air conditioner was running. So as long as you're going 35+, the Popcharger isn't sucking in air that's much hotter than a CAI.
Below 40 mph, intake temps got hotter the slower I drove (obviously). This increase was exaggerated when the a/c was running.
When stopped and idling, intake temps got pretty hot... about 130 degrees after sitting idle for a couple of minutes. It would hit about 140 with the a/c running. After I started driving, the intakes temps immediately dropped back down.
These results were all taken over a number of days when the temp outside was in the 80s. In each case I let the engine warm up to full operating temp before taking any readings. After this testing, I decided the Popcharger was just fine for my purposes. I *love* the sound, and the intake temps were acceptable as long as I was moving, so I'm okay with it.
Great post! very helpful!
Old Oct 2, 2006 | 09:34 AM
BlackZero6's Avatar
BlackZero6
thanks jreiter....ill keep it for now....maybe ill make up some aluminum box....off to the homedepot
Old Oct 2, 2006 | 12:12 PM
jreiter's Avatar
jreiter
Take a look at K&N's Typhoon intake. Maybe copy the way they did it if you feel like a DIY project. Their's is basically like the Popcharger (an open filter in the engine bay with a simple heat shield/box, but the Typhoon has an addtional air tube that runs from the box down to the grill. When moving, this will shove even more outside air over the filter. I'd guess this might result in slightly lower intake temps while moving. You could probably rig up such a tube yourself if you wanted.
Old Oct 2, 2006 | 01:18 PM
jadaniya's Avatar
jadaniya
if you take it off you can sell it to me
Old Nov 3, 2006 | 05:34 AM
mberthia's Avatar
mberthia
I put on a cover using aluminum roof flashing. I bought a roll of the flashing at home depot for less than 10 bucks and cut it to shape and added 3 holes using existing screws for mounting. I'll post a picture later. I checked the temperature of the flashing right after coming off the racetrack and it was absolutely cold. Of course if I wait a few minutes after parking in the pits, it would get heat soak.
Old Nov 3, 2006 | 06:02 AM
THE TECH's Avatar
THE TECH
The best boxes are made out of plastic, cf, etc. Metal generally retains more heat than plastics. That being said, I'd just stick with your popcharger. There hasn't been any significant gains of other intakes over the popcharger. So unless you just want something different, stick with what you've got.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
