Should I remove my popcharger
Old Sep 28, 2006 | 09:32 AM
BlackZero6's Avatar
BlackZero6
Default Should I remove my popcharger
im getting the nismo v2 front bumper and to what i understand it has an intake scoop...since there are no affordable cold air boxes...i figured i would put my stock intake housing with a high flow filter.......of course im trying to keep hot air out..
....what do you guys think?
Old Sep 28, 2006 | 09:36 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
um, why not leave it? The v2 bumper should convert your poopcharger to a cai. It has a duct the pushes air to the hole in the front where the varis air duct feeds.
They should be compatible.
Old Sep 28, 2006 | 09:37 AM
BlackZero6's Avatar
BlackZero6
no the reason i wanna take out the pop charger is because the hot air from the engine bay gettin into the intake
Old Sep 28, 2006 | 12:31 PM
BlackZero6's Avatar
BlackZero6
anybody?
Old Sep 28, 2006 | 12:33 PM
bonusfrag's Avatar
bonusfrag
poopcharger...lol
Old Sep 28, 2006 | 12:35 PM
GSXR-Z's Avatar
GSXR-Z
Originally Posted by bonusfrag
poopcharger...lol
I wonder what one of those looks like?
Old Sep 28, 2006 | 12:42 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
probably like chit.
op, the duct and heat shield on the POPcharger will bring in cold air. The v2 duct goes in the front opening and funnels in COLD air to your POPcharger.
do i need to draw a diagram?
Old Sep 28, 2006 | 12:51 PM
BlackZero6's Avatar
BlackZero6
dude im not new to this...dont talk to me like you know better....
ok the v2 scoop brings in cold air-great
the pop charger heat shield is worth crap and lets all the warm air in-bad
now in almost all the professionally modified Z's ive seen that they keep the factory air box.....so my question is....take the popcharger out? or will the v2 air scoop balance it out?
Old Sep 28, 2006 | 04:01 PM
jasonlee4180's Avatar
jasonlee4180
I say if you enjoy the sound, I'd keep the *poopcharger on.
Otherwise...if you're that hardcore (those that drive around without the spare), the better overall performing intake is obviously the stock box as attributed by protuners.
I'm sure drivability would be better with the box, but power gains from the pop are negligable. So is that WOT sound worth the sacrifice for a little bit better driveability?
Old Sep 28, 2006 | 04:54 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
won't the cold air passing through the varis duct like hole cool down the air inside the engine bay?
Old Sep 28, 2006 | 05:21 PM
Cannysage's Avatar
Cannysage
NEVER EVER take out the glorious POPCHARGER! it should be taken out only when you're cleaning it.
Old Sep 29, 2006 | 06:44 AM
BlackZero6's Avatar
BlackZero6
yeah thats what im leaning towards at the moment...yes i love the sound...but im trying to squeeze every bit of power out of this thing
Old Sep 29, 2006 | 09:22 AM
BlackZero6's Avatar
BlackZero6
has anyone made a cold air box......other than arc
Old Sep 29, 2006 | 10:13 AM
davidf's Avatar
davidf
It should'nt be hard to cover that filter with a piece of alum. sheet metal. If done correctly it will actually look nice.
Old Sep 29, 2006 | 01:26 PM
Nismo 350z's Avatar
Nismo 350z
Stillen has. I dont get it. I know the pop charger draws hot air from the engine bay but wouldnt the duct draw cold air in? Isnt that why people get the Varis air duct with the pop charger for the CAI effect?
Old Sep 29, 2006 | 03:33 PM
jasonlee4180
If someone would just create a sealed stock fitting box that will fit my popcharger, I'll take two of those...
Old Sep 30, 2006 | 10:19 AM
davidf's Avatar
davidf
The only problem I see with Stillens is the cone filter looks sealed with a chrome cap on the end and the Pop C. is open on the end which IMO draws more air through the front.
Old Sep 30, 2006 | 10:24 AM
ArCtM's Avatar
ArCtM
wouldnt cold air coming in push back the hot air anyways?
Old Sep 30, 2006 | 06:50 PM
jreiter's Avatar
jreiter
For what it's worth, I've done a decent amount temperature testing with my Popcharger. My findings matched up with what another person found and posted about quite a long time ago. (I forget who it was who did the initial testing.) I used an OBD scan tool to note the intake temperature (as reported by the car's computer) in various conditions. The results basically went like this:
At 35+ mph, the intake temp was about 5-10 degrees higher than outside ambient temp. This was also true when the air conditioner was running. So as long as you're going 35+, the Popcharger isn't sucking in air that's much hotter than a CAI.
Below 35 mph, intake temps got hotter the slower I drove (obviously) since there is less air flowing into the engine bay. This increase in temp was exaggerated when the a/c was running.
When stopped and idling, intake temps got pretty hot... about 130 degrees after sitting idle for a couple of minutes. It would hit about 140 with the a/c running. After I started driving, the intakes temps immediately dropped back down.
These results were all taken over a number of days when the temp outside was in the 80s. In each case I let the engine warm up to full operating temp before taking any readings. After this testing, I decided the Popcharger was just fine for my purposes. I *love* the sound, and the intake temps were acceptable as long as I was moving, so I'm okay with it.
