DC Header Help!!!!!!!
Old Sep 30, 2006 | 03:17 PM
genegoesfast's Avatar
genegoesfast
Default DC Header Help!!!!!!!
I just had a set of DC headers installed on my car and the driver's side doesnt even begin to fit! They had to bend one of the pipes near the collector to even get it mounted, now it rubs on the steering column still pretty much all the time...and I'm freaking out. How on earth could the design be this bad? Does anybody have these headers installed? Any problems? How can I get DC to fix this?
Old Sep 30, 2006 | 03:21 PM
THE TECH's Avatar
THE TECH
Just to make sure, are these REAL DC headers or some copy of the DC header? If they are indeed real, take some pictures and contact DC on Monday and see what they have to say. If they are a copy, then it is buyer beware most likely.
Old Sep 30, 2006 | 03:49 PM
genegoesfast
I beleieve these to be totally legit...they have the dc logo welded on...i guess that could be done by anyone...I'll post pics shortly.
Old Sep 30, 2006 | 03:53 PM
genegoesfast
DC Header Help!!!!!!!-4.jpghere
Old Sep 30, 2006 | 07:39 PM
blueper4mancez's Avatar
blueper4mancez
dont tell me you got these off ebay , if so good luck
Old Sep 30, 2006 | 09:01 PM
genegoesfast
nope member on this site
Old Sep 30, 2006 | 09:10 PM
lovetoclown's Avatar
lovetoclown
I have DC headers and they fit perfect.
Old Oct 1, 2006 | 08:28 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
I have them too - no issues. Have you checked the DC Site for pix to compare yours?
Rick
Old Oct 1, 2006 | 09:07 AM
HoldThisForMe's Avatar
HoldThisForMe
who installed them?
Old Oct 1, 2006 | 12:44 PM
genegoesfast
nissan dealership
Old Oct 1, 2006 | 03:42 PM
Acree's Avatar
Acree
I know this is a stretch, but any chance you bought headers for a right hand drive Z? I'm running strup headers (which are pretty much the same design) and they slid in with no problems what so ever.
-Acree
Old Oct 1, 2006 | 05:17 PM
genegoesfast
ooohh very possible. It's seems like there is plenty of clearance on the passenger side but absolutely none on the driver's. I just find it highly unlikely though...not many imported z's in the states.
Old Oct 1, 2006 | 09:00 PM
JhayRCruz's Avatar
JhayRCruz
i got DC headers and mine fit perfectly! Hope u resolve this issue! good luck!
Old Oct 2, 2006 | 07:56 AM
THE TECH's Avatar
THE TECH
I wasn't aware that DC made headers for RHD. May want to check on that one.
Old Oct 2, 2006 | 08:04 AM
As you know, headers are not designed to be bent. Bending headers may likely result in cracked welds. You mentioned the upper portion of the steering shaft rubbing. The shaft has no outer sleeve for protection. Wear would frighten me.
Best of luck.
Old Oct 2, 2006 | 08:10 AM
MikeEwithTheZ's Avatar
MikeEwithTheZ
ya its tight on the drivers side...i did my top speeds myself and they fit like a glove
Old Oct 2, 2006 | 08:33 AM
genegoesfast
yes I agree with frightening steering shaft wear hence I'm not driving my car....I'm f'ed
Old Oct 2, 2006 | 09:56 AM
Zquicksilver's Avatar
Zquicksilver
Best of luck.
+1...
the solid steel steering shaft will eventually wear a hole in the headers if they rub over time.
Zquicksilver
Old Oct 2, 2006 | 11:45 AM
Road Warrior's Avatar
Road Warrior
mine fit perfect too...i did remove the steering shaft however to get them in making the intall and fit easier
if they have bent the tubing on the header, i would think this would effect performance...but how much did they modify?
B Esquire
Sep 24, 2015 07:52 AM
z33z_nutz
Sep 23, 2015 07:22 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
EnjukuRacing
Sep 9, 2015 06:42 AM
