Ditching My Cats...whats next step
Old Oct 12, 2006 | 04:38 AM
Barzten1's Avatar
Barzten1
Default Ditching My Cats...whats next step
Well I'm moving to a different part of New Mexico and they don't require emissions tests. I have the Vortech SC and was wondering what pipes to go with my Nismo exhaust and will I have to retune once they are on? Will I have any issues with backpressure that i supossedly need to attain proper boost? Thanks for any help.
Old Oct 12, 2006 | 04:40 AM
Gumpdriver's Avatar
Gumpdriver
Some Kinteix cats
some some good Headers
Old Oct 12, 2006 | 04:45 AM
Barzten1's Avatar
Barzten1
I have Nismo catback exhaust and stillen headers as is. I also have the Kinetix SSV manifold. I was wondering if the next step would be to lose the cats or a highflow cat or test pipes? Will I need a retune after adding them?
Old Oct 12, 2006 | 05:14 AM
plumpzz's Avatar
plumpzz
As far as backpressure is concerned, you should not loose power although you'll be making less boost with the same pulley... You will need a tune after adding test pipes or HFC. They change your A/F drastically and unpredictably. I went really rich after i put test pipes on, only for the computer to lean it out after a few months.
Old Oct 12, 2006 | 12:12 PM
Barzten1's Avatar
Barzten1
So would you go with HFC or test pipes or leave it as is?
Old Oct 12, 2006 | 08:11 PM
Barzten1's Avatar
Barzten1
Any thoughts?
Old Oct 12, 2006 | 09:24 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Test pipes all the way.
Old Oct 22, 2006 | 07:12 PM
DanielW's Avatar
DanielW
how much more of a gain will you get from test pipes than high flow cats? and is the raspiness worth it? I've heard that even the resonateed ones are a bit raspy.
_bit
Oct 2, 2015 07:49 AM
