Exhaust Leak When Installed Y-Pipe
Old Oct 14, 2006 | 01:16 PM
thirty5ounces's Avatar
thirty5ounces
Default Exhaust Leak When Installed Y-Pipe
Installed my Y-pipe about 2 weeks ago and have a very smal exhaust leak ever since, I thought it might be the cheap gasket but I bought a new one from Nissan and I am still having leak out of the same gasket. Any ideas, i didnt tighten them really tight because i didnt want to bend the flange, and it its the back gasket not the ones that hooks up to my test pipes. ANY IDEAS TO HELP SOLVE PROBLEM.....
Old Oct 14, 2006 | 01:36 PM
breed's Avatar
breed
it might be leaking from the flex pipe.
Old Oct 14, 2006 | 02:10 PM
undrgnd's Avatar
undrgnd
First, tighten all bolts to spec torque. If it's still leaking, look for the leak. If it's at the rear joint, tighten it a little more. I snugged it down pretty good but still had a very small condensation drip, but after a while, it plugged up.
Old Oct 14, 2006 | 02:27 PM
thirty5ounces
yea i also have a small condensation drip, ive found the leak its on the rear joint, i guess i will tighten a little more but im just worried about bending that flange.
Old Oct 14, 2006 | 04:58 PM
undrgnd's Avatar
undrgnd
I put ~35ft-lbs on it, and I didn't see any distortion (JIC Y-pipe, Amuse R1000 exhaust). OEM specs are ~25ft-lbs. Unless you can hear and feel a major leak, don't mess with it. Condensation will drip out even through a pretty small space.
Old Oct 14, 2006 | 05:57 PM
thirty5ounces
cool man thanks for the help
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Li1ag
Sep 28, 2015 02:07 PM
