how much HP??
Old Oct 19, 2006 | 02:01 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default how much HP??
how much whp increase will i get from a pop charger, and nismo exhaust OR pop charger and headers on stock exhaust.
Old Oct 19, 2006 | 02:03 PM
zand02max's Avatar
zand02max
Do you have stickers?
Old Oct 19, 2006 | 02:08 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You won't get much without tuning, maybe 7 or 8
also it's pointless to do headers unless you change out the (very restrictive) stock cats.
Old Oct 19, 2006 | 02:16 PM
superchargedg's Avatar
superchargedg
Damn Noobs
i agree with wired,very little is gained na on this engine.you would have to go to the extreme to get more then 30rwhp out of this motor.nissan really did do a good job on this engine.
Old Oct 19, 2006 | 02:19 PM
Ilov350ZEE's Avatar
Ilov350ZEE
how much to get it tuned??? sorry im new to this. do i need to get the car tuned everytime i put engine mods. What would be a best setup to achieve a little over 300 hp and stay legal, my budget is $1,700
Old Oct 19, 2006 | 03:00 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
test pipes, motordyne 5/16" spacer, popcharger, and technosquare reflash
IMO that would get you the best bang for your buck with that budget
Old Oct 19, 2006 | 03:25 PM
Ilov350ZEE's Avatar
Ilov350ZEE
is test pipes legal, and the other mods above will work well with stock exhaust??
Old Oct 19, 2006 | 08:22 PM
Machupo's Avatar
Machupo
Use the search button, you'll learn more that way.
Old Oct 20, 2006 | 12:08 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Depends on state law. You may wish to go with high flow cats instead, if you don't want to run test pipes.
the mods above work fine with the stock exhaust
Old Oct 20, 2006 | 02:54 AM
Ilov350ZEE's Avatar
Ilov350ZEE
with the spacers do i still need the reflash to get the hp gain???
Old Oct 20, 2006 | 03:15 AM
undrgnd's Avatar
undrgnd
^^^ It's a spacer, just one. If you want to learn something about your car, search, it's all here. If you want to be spoonfed so you can blindly follow, keep asking, but remember, you're only getting a couple of folks' opinions.
Old Oct 20, 2006 | 03:52 AM
savvy's Avatar
savvy
since you have an 06 i would get the MREV2 + the spacer. This setup with no tune will get you somewhere near +17whp and really open up the mid to top end
also there is no way possible you will get 300whp for $1700. That mark requires some pretty serious $$$
Old Oct 20, 2006 | 04:02 AM
jeff_chen0209's Avatar
jeff_chen0209
with $$1700... u cant realli do anything to the engine even u do the gain is pretty minimal " little more than 300hp..sure 310hp for $1700".... i would suggest u find some nice cheap used exhuast and a jwt pop charger...then use the rest to do exterior..maybe lower it....blabla...best u can do for 1700...and sure u will hav no problem wif the laws.....then do more mods on the engine when u hav enough $$.....sometimes HP is not everything ... so ...dun worry about the hp since the z is already fast ... well good luck ..
Old Oct 20, 2006 | 04:25 AM
savvy's Avatar
savvy
your best bet is what Wired said, get test pipes if they are legal, popcharger, MREV2 and spacer and a reflash for the ecu. As far as the reflash goes, make sure you are done all your mods before you reflash it. So if you plan on exhaust and headers later on down the road, you may want to wait to get it reflashed....unless you want to spend the $600 over again
Old Oct 20, 2006 | 05:33 AM
jeff_chen0209
i think this is wut u lookin for ....lol........
http://cgi.ebay.ca/20HP-POWER-SPEED-...QQcmdZViewItem
Old Oct 20, 2006 | 05:45 AM
savvy's Avatar
savvy
speed chips rule
Old Oct 20, 2006 | 12:02 PM
03zsmith25's Avatar
03zsmith25
turbonator...nuff said
Old Oct 20, 2006 | 12:14 PM
Cannysage's Avatar
Cannysage
Popcharger+tune= PWN EVERONE!
Old Oct 20, 2006 | 12:21 PM
z-u-later's Avatar
z-u-later
Stock + NISMO sticker = 400+hp, 300+tq
