Went Back to STOCK INTAKE, CHECK ENGINE SOON LIGHT ON NOW!! HELP
Old Nov 4, 2006 | 06:41 AM
original786's Avatar
original786
Default Went Back to STOCK INTAKE, CHECK ENGINE SOON LIGHT ON NOW!! HELP
Well i had a nismo cold air intake, im parting my car out
so i went back to my stock intake, and when i started the car the check Engine light came on,
so i was like whats that all about, so i realized i left the intake sensor clip off, so i clipped it back on the intake sensor, then tried to start it, and it is still on??
how do i remove it
the check engine light was never on before
is there a reset button??
Old Nov 4, 2006 | 06:51 AM
lb's vq35's Avatar
lb's vq35
You May Have To Restart The Ecu Its A Hassel To Do It But The Easiest Is Removing The Neg. Cables From The Battery And Pump The Brakes To Discharge The Ecu Maybe That Will Work
Old Nov 4, 2006 | 08:12 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
reset ecu, instructions can be found in the top 100 questions thread
Old Nov 4, 2006 | 08:26 AM
original786
thanks, i just found out
but one question
do i have to mess with the ECU??
or do i just remove my negative wire from batter, leave it off for a night, and then pump the brakes several times . and then connect the negative terminal back, that should solve the problem??
Old Nov 4, 2006 | 08:30 AM
rockinbboy's Avatar
rockinbboy
There are two ways to reset the ECU.
Method 1: disconnect battery
Method 2: a combination of pressing the accelerator and turning the key. I don't know the right sequence.
You shouldn't have to pump your brakes if you are disconnecting the battery..at least thats my understanding.
Old Nov 4, 2006 | 08:42 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
but one question
yes that will work no problem
Old Nov 4, 2006 | 08:46 AM
original786
ok i disconnected the negative terminal. i will keep yall posted,
let you guys know tomorrow
Old Nov 4, 2006 | 08:57 AM
titanjc's Avatar
titanjc
If you're looking for something more immediate, the ECU reset method is posted on TechnoSquare's website. Google it up.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
