LoOkiE WhaT i GoT PpL
Old Nov 12, 2006 | 04:27 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Originally Posted by Hraesvelg
Kinda like when someone gets a new Z, and another member says "post pics!" like they don't know what a plain *** stock Z looks like. damn noobs...
It's more to make them feel good and to get them use to posting up pics for future mods. Butcha knowthat...Kewl
Old Nov 12, 2006 | 04:31 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
What's next?
"Look everyone, it's my first fill up at the gas station!!!!"
"Do I use diesel or regualr gas?"
*Will shank the first newb to post pics of an airfreshner*
Old Nov 12, 2006 | 04:59 AM
Xx SiFaKa's Avatar
Xx SiFaKa
Do what I did. Take off the rubber tubing on your injen filter and bolt the air filter directly to the MAF housing... actually there may be a metal part between the filter and MAF housing it's been a few years... But regardless the filter is in the same spot as the popcharger in the JWT. Save you some cash
What about a heat shield that JWT provides for their Intake system, do I need one? I'm interested in this because the where the filter is placed, it's hard to get to and clean it out.
Old Nov 12, 2006 | 05:11 AM
Xx SiFaKa's Avatar
Xx SiFaKa
So you don't like my new mod HRAESVELG? Even though it smells like peech?
Old Nov 12, 2006 | 05:56 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Tree FTW!
not.
Hope your Z is blue, if not you need a silver tree. Make sure it has little blinking lights too....
Old Nov 12, 2006 | 05:58 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Popcharger FTMFW!!!
Old Nov 12, 2006 | 06:00 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
What's next?
LMAO
My first wash, OMG rain, or how about oil change??
It's just like having your first kiddo!!
Old Nov 12, 2006 | 06:28 AM
stein's Avatar
stein
He's excited about his first mod, give him a break, man! I know when I started the first few mod on my previous car the initial performance & sounds was breathtaking.
Old Nov 12, 2006 | 06:30 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
It's easy to clean when it's set up like a Pop Charger. The heat shield will most likely help when at idle (for under engine heat) but under speed you will get plenty of fresh air.
Old Nov 12, 2006 | 06:31 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
NO!
*E-Shanks SiFaKa in the gut*
Old Nov 12, 2006 | 08:02 AM
Xx SiFaKa's Avatar
Xx SiFaKa
Tree FTW!
not.
But I couldn't find a silver tree.....
Sweetness!!!!
Last edited by Wired 24/7; Nov 12, 2006 at 07:19 PM. Reason: use the edit button!@!
Old Nov 12, 2006 | 09:18 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Sweetness!!!!
I did the regular install at first, but the filter got crapped up quick. The short ram conversion sounds better too.
Old Nov 12, 2006 | 09:25 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Photoshop and add lights
Old Nov 12, 2006 | 09:31 AM
Xx SiFaKa's Avatar
Xx SiFaKa
I just tried taking it out. It seems to hard trying to adjust it right to get it out and what not
.I took of the metal belt tightner right off the maf sensor on the rubber tube, and the rubber tube part didn't seem so too easy to take off? What is some advise you can ive me for the litle problems that com along when taking it out? I don't know how to get the lower half of the intake out because of the way it bends? Is it even worth it? Do you think I should just let it be?
You know what, I just wanted to try something different! Leave me alone!
Last edited by Wired 24/7; Nov 12, 2006 at 07:20 PM. Reason: USE THE EDIT BUTTON!!!!111
Old Nov 12, 2006 | 09:49 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
I keeed, I keeed. You aight. If you like it keep it.
I had one under my seat, the can type, it fell over so I took it out cuz it leaks. A Z that smells good is so much sexier than one that stinks.
Old Nov 12, 2006 | 10:15 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Water with a little soap helps, just be sure to wipe it all up when you're done.
See how this dude set up his Nismo: https://my350z.com/forum/showthread....njen+short+ram
Old Nov 12, 2006 | 10:19 AM
Xx SiFaKa's Avatar
Xx SiFaKa
I might just leave it. It doesn't rain too much in tucson, so I should only worry when it does rain. If I do end up doing it, then thanks for the help. Does it actually pull harder/sound louder?
Old Nov 12, 2006 | 10:20 AM
  #38
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Here it is: https://my350z.com/forum/showthread....njen+short+ram
It does sound cooler with the tube shortened.
Old Nov 12, 2006 | 10:23 AM
  #39
Xx SiFaKa's Avatar
Xx SiFaKa
You do know I photoshopped that air freshener in right?
Damn, that was a quick responce. I guess I will do it. I mean I have nothing to loe but more to gain so I guess I will go ahead and try it so I can hear the difference in sound/pull.
Just haven't gotten a totally clear answer on how to go about moving the bottom portion of the intake past the MAF sensor? If I un hook the rubber tube should I be able to get it off just by that?
Ok how in the hell do you get to the damn filter? I got the red riber of the MAF sensor and I couldn't find out how to get the rest of it to come through? Can someone give me an answer to this?
Last edited by Wired 24/7; Nov 12, 2006 at 07:20 PM. Reason: use the friggin edit button!!!!111
Old Nov 12, 2006 | 11:05 AM
  #40
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Yeppers...strut bar scribbles too...
