Only 35th and 06 revups with test pipes respond
Old Nov 28, 2006 | 10:59 AM
thawk408's Avatar
thawk408
Originally Posted by 97supratt
Is the o2 sensor touching the non fouler? If it is then there is your problem. I suggest removing the o2 sensor and the non foulers. Tighten the o2 sensor onto the non foulers and look at the end of the non fouler. If you drilled the non fouler incorrectly, then your o2 sensor will have problems detecting the correct amount of gases.
Im not sure if mine is touching or not, I will check later. Why does it matter if they are touching?
Old Nov 28, 2006 | 11:02 AM
97supratt's Avatar
97supratt
o2 sensors are very sensative, especially on the newer 04.5+ models (wideband sensors).
If half of the sensor is blocked off the readings will be incorrect and throw a CEL.
Old Nov 28, 2006 | 11:31 AM
thawk408's Avatar
thawk408
Mine seemed to work for awhile, then all of sudden about half a year ago it came on when I was on a road trip. It has been on every since.
Old Nov 28, 2006 | 11:45 AM
ML2000's Avatar
ML2000
I was doing a little research, I came a cross this code scanner that says it's able to turn off the CEL.
http://www.amazon.com/Actron-CP9175-...8&s=automotive
Let me know what you think.
Matt
Old Nov 28, 2006 | 12:09 PM
97supratt's Avatar
97supratt
Anything could have happened on that road trip and the o2 sensor might have been damaged. If you are willing to test it out, just put the stock cats back on, if the CEL doesn't disappear you know for sure it's your o2 sensor thats bad.
Old Nov 28, 2006 | 12:11 PM
97supratt's Avatar
97supratt
Matt
If you're gonna do that, you might as well buy the Cipher diagnostic tool. You have more features, plus its very user friendly. Wired24/7 has one and it works great, i'm sure he'll chime in here real soon for some information.
Old Nov 28, 2006 | 12:28 PM
jtgli's Avatar
jtgli
YEa I used the lock tight on mine and when I reset the cel comes back 5 miles or so later, didnt use it on my bros and his cel comes back about 20 miles or so later. Check the sensors non of them on either car are touching anything and nothing is blocking them. About this diagnostic tool, is it the aam cipher your refering too? And will it keep the cel off?
Old Nov 28, 2006 | 12:34 PM
97supratt's Avatar
97supratt
Yes I was referring to the AAM Cipher tool. I don't think it'll keep the CELL off but it will tell you which code it is and it resets it.
Old Nov 28, 2006 | 07:54 PM
ML2000's Avatar
ML2000
Thanks for the info 97supratt.
Matt
Old Nov 28, 2006 | 10:59 PM
97supratt's Avatar
97supratt
Matt
np.
Old Nov 29, 2006 | 12:07 AM
thawk408's Avatar
thawk408
Anyone tried these....
http://cgi.ebay.com/ebaymotors/O2-Se...spagenameZWD1V
Old Nov 29, 2006 | 12:29 AM
Mazinger Z's Avatar
Mazinger Z
This is one reason why I didn't get TP's. I don't want to get a CEL and then later on, if something is really wrong, I won't know because I'll just assume it's the TP's.
Old Nov 29, 2006 | 10:25 AM
97supratt's Avatar
97supratt
You can definitely use a o2 simulator but the CEL shouldn't come back after the non-fouler trick.
Old Nov 29, 2006 | 11:26 AM
jtgli's Avatar
jtgli
Will the o2 sims work alright with the Z?
Old Nov 29, 2006 | 01:07 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Since 97supra said I would :P
Yeah I have nothing but good things to say about cipher.
It's a great tool for eliminating about 99% of the unknowns associated with your car. Great diagnostic tool for basically every possible problem you could have.
Check what CEL's mean and easily reset them. Turn up the idle, or advance timing a couple of degrees to unlock some power.... and lots more
Old Nov 29, 2006 | 02:23 PM
97supratt's Avatar
97supratt
+1 Having the ability to look over vital engine functions is always a good thing in my book.
Old Dec 25, 2006 | 07:22 AM
RBlover69's Avatar
RBlover69
yea i love the idea of test pipes but hi flow cats are looking better and better. Just not wanting the rasp and cel issues. I dunno maybey i need to here a test piped car to hear and get a feel of what its like?
Old Dec 25, 2006 | 09:43 AM
  #38
9kFever's Avatar
9kFever
I have the HELP Spark Plug Defoulers and I do not have a CEL. Originally I thought I did get a CEL but it turned out to be for the throttle positioning sensor. Anyone actually used a scanner? Or just assumed it was the tps?
Old Dec 25, 2006 | 07:42 PM
  #39
Armitage's Avatar
Armitage
How long have you been running the Defoulers?
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
