flowmaster exhaust..... redneck?
Old Dec 6, 2006 | 11:15 PM
joshtow15's Avatar
joshtow15
Default flowmaster exhaust..... redneck?
ok so i've read so much my eyes hurt, but i couldn't find if some one has tried to install a custom a.k.a. redneck exhaust, such as mabey two flowmaster exhausts with piping. This has worked on all my other vehicles, even got a better dyno result with my old 300z vs the performance one made for my vehicle. just wanted a little info if available, not sure how it would respond, backpressure an issue? Any info would be great.
Old Dec 6, 2006 | 11:21 PM
Mike Wazowski's Avatar
Mike Wazowski
give it a try and post the dyno results (before and after of course)
Old Dec 7, 2006 | 07:22 AM
97supratt's Avatar
97supratt
It might actually sound good, flowmaster mufflers have always created a deep sound.
Old Dec 7, 2006 | 07:25 AM
cavallino33's Avatar
cavallino33
I was thinking about this as well. I don't know though.
Old Dec 7, 2006 | 07:32 AM
tranceformer95's Avatar
tranceformer95
Flowmaster mufflers are pretty cheap, i imagine you could get a decent used set for dirt cheap and fabricate a custom for cheap. And if you don't like it, atleast you didn't pay alot for it.
Old Dec 7, 2006 | 07:44 AM
G1s Z's Avatar
G1s Z
+1, sounds like its a worthwhile idea
Old Dec 7, 2006 | 08:05 AM
tranceformer95
I'd say hit up a junkyard and head for where they keep the Mustangs. Sad but true, theres plenty of wrecked Mustangs out there that have flowmasters.
(me = ex-mustang driver)
Old Dec 7, 2006 | 08:09 AM
rocks's Avatar
rocks
If i remember flow master 40 series are around 40$ each from nearly any muffler shop. I had one 40 series with a 3" pipe on my 928 from the manifolds back and it was extreamly loud.
Old Dec 7, 2006 | 08:26 AM
z-u-later's Avatar
z-u-later
Go with Magnaflow instead. There are a couple of forum members who have installed a Magnaflow muffler and they're happy with it. Fairly inexpensive mod for less than $200.
Old Dec 7, 2006 | 09:02 AM
dTor's Avatar
dTor
I'm using Dynomax super turbo or some such name with a Magnaflow resonated x-pipe on my custom true-dual setup. It sounds really, really good. Smooth, low tone, slightly louder than stock, absolutely no rasp, and definetely an improvement in performance over stock. The only thing is that, with the particular design of muffler I got (center in, offset out) the shop could not line them up symmetrically because of the way the pipes had to be bent within the confines under the car. They said if the mufflers were offset in/offset out, then they would have been able to get them lined up perfectly. So, make sure that what you get will fit, and get offset/offset.
Old Dec 7, 2006 | 01:29 PM
joshtow15's Avatar
joshtow15
thanks everyone i think this little project deserves some attention as soon as i get a little spare time from work, see what i can come up with, will post pics and sound clip but will probably be after christmas, just so we know what kinda time frame,but if anyone else is feeling frisky have at it and lets see what happens.
Old Dec 7, 2006 | 02:54 PM
Buy some resonators and mufflers and pipe and just do it.
Old Dec 7, 2006 | 05:44 PM
bofa's Avatar
bofa
Why's it gotta be a redneck thing?
Old Dec 7, 2006 | 05:51 PM
undrgnd's Avatar
undrgnd
My prediction is that this is going no further that this thread.
Old Dec 7, 2006 | 09:34 PM
Jaegermeister2k's Avatar
Jaegermeister2k
Flowmaster does everything exscept what the name implies. And that's flow. Coming from a world of domestic V8's i can tell you that flowmaster is usually nowhere near the top of anybody's list. They can sound very nice on a mustang, and some other cars. But as far as flow is concerned, there are much better mufflers. Magnaflow comes to mind.
Old Dec 7, 2006 | 11:07 PM
chris'smax's Avatar
chris'smax
+1 heard the same from some domestic buddies.
One very knowledgable freind of mine who works at the local domestic performance shop high reccomends Dyno-max though
Old Dec 7, 2006 | 11:10 PM
jakesford's Avatar
jakesford
yup, but if you were to do it, I would go with the 70 series (i think?) its the one made for camaro's. Its like a 40 series that is setup like the stock Z muffler with on inlet and an outlet on each end...
Old Dec 8, 2006 | 12:39 AM
undrgnd's Avatar
undrgnd
^^^ Right on! That should make you the envy of all your friends, a Camaro muffler on a Z. Then you can get some pickup tires and be a real redneck.
Old Dec 8, 2006 | 03:18 AM
Jaegermeister2k
I had dynomax bullets on my camaro. They look like a piece of pipe, with a 3" hollow space through and the muffling part around it. Flows like a test pipe, but quiets the car down quite a bit, and gives it a nice sound.
Old Dec 8, 2006 | 08:37 AM
rocks's Avatar
rocks
Flow masters have chambers in them, they are not a straight through design.
