throttle body bypass
Old Dec 30, 2006 | 01:07 PM
michael22force's Avatar
michael22force
Default throttle body bypass
does anybody know how to install a throttle body bypass kit. and if it is works well without messing anything up?
Old Dec 30, 2006 | 05:40 PM
DavesZ#3's Avatar
DavesZ#3
Are you referring to a coolant bypass kit? The TB is heated by radiator fluid that passes through the neck of the upper plenum. There is a kit (Motordyne) and some DIYs on how to bypass the TB allowing it and the plenum to run cooler.
Old Dec 30, 2006 | 06:36 PM
michael22force
yeah thats exactly what i am talking about.
Old Dec 30, 2006 | 06:39 PM
plumpzz's Avatar
plumpzz
Doesnt do jack. If ur gonna buy it, its not worth it. If it came with ur kit, just use it.
Old Dec 30, 2006 | 06:50 PM
michael22force
well i got it cause it was 15 dollars on ebay. just wondering if it was a hard install. all it is is a tube right?
Old Dec 31, 2006 | 05:38 AM
DavesZ#3's Avatar
DavesZ#3
I don't know about the ones on eBay, I got one from Motordyne. The DIY ones I've seen (probably what you find on ebay) is just a tube to join the two hoses together. That let's you bypass the plenum section that heats the TB.
Not hard to install at all, just a little tough getting the hoses off because then connect under the plenum neck at the back of the engine.
Old Jan 3, 2007 | 11:57 AM
NA&CH's Avatar
NA&CH
http://cgi.ebay.com/ebaymotors/03-06...QQcmdZViewItem
I just saw this. It could be made by anyone. Would it help is the question.
The hose is no prob.
The fitting is no prob.
What are the two small black things? OP can you take pics of the pieces?
Also what part of FL are you from??
Thanks
Old Jan 3, 2007 | 01:52 PM
DavesZ#3's Avatar
DavesZ#3
My guess is that they are spring-type hose clamps, similar to what is on the OEM hoses. Because it's connecting to the coolant and it's under pressure, you need some kind of clamp to make sure that the hose doesn't come off the connector.
Old Jan 3, 2007 | 02:44 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It won't do anything.
But... if you really want
All you need is to cut the coolant hose going to the TB and install a valve with clamps. Open or shut the valve manually.
Justin100
Nov 25, 2021 06:26 AM
