Nismo Exhaust Broke
Old Jan 7, 2007 | 10:47 PM
doskiez's Avatar
doskiez
Default Nismo Exhaust Broke
I have test pipes and a nismo exhaust on my car and over the break i had to fix a cracked weld on my test pipe. I did and mentioned it to a buddy who races them and he suggested i make a brace for them because he had the same problem. I did and a weld on the nismo exhaust broke a few weeks later.
Any ideas?
Thanks
Old Jan 8, 2007 | 08:23 AM
SergEK's Avatar
SergEK
Add some flex pipes???
Old Jan 8, 2007 | 09:26 AM
z-u-later's Avatar
z-u-later
No, I think the NISMO exhaust is cat-back. They have been known to have problems with their y-pipe. OP, what part of the NISMO exhaust's weld broke?
Old Jan 8, 2007 | 11:56 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Things will break at stress points.
If the test pipes or cats crack, there was a stress point at the test pipes or cats. Repeated thermal cycles and stress cycles caused material failure (this is always the case).
By introducing a brace that is not correctly designed, you will create a stress point somewhere else (such as in the cat-back portion of the exhaust). If you create a brace that is properly engineered, it will eliminate all stress points.
Old Jan 26, 2007 | 02:34 PM
doskiez's Avatar
doskiez
The brace i made was a copy of the one spl parts has on their 350 racecar but as an update i added flex joints to the test pipes in front of the brace and it has solved the problem so far.... i have had no problems out of it since
Old Jan 26, 2007 | 02:43 PM
This thread needs some photos.
Old Jan 26, 2007 | 05:49 PM
THE TECH's Avatar
THE TECH
Hmm. I had never heard of a Nismo having any issues like that. Mine had zero probs.
Old Jan 26, 2007 | 05:50 PM
plumpzz's Avatar
plumpzz
get APS, strup, or turboXS test pipes. theywont crack.
Old Jan 26, 2007 | 09:48 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
There are other threads here about Nismos Ys cracking with Crawford HF cats and some test pipes. It was a hot topic about a year and a half ago. Later Nismo systems have a small gusset at the Y weld, I imagine this was to try and combat this issue.
Chris
Old Jan 27, 2007 | 10:50 AM
THE TECH's Avatar
THE TECH
^^Interesting. I had mine with the Kinetix cats and had zero issues. Maybe I just got lucky.
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
