q45 throttle body
Old Jan 9, 2007 | 09:03 PM
o snap its eric's Avatar
o snap its eric
Default q45 throttle body
has anyone tried this?
Old Jan 11, 2007 | 01:37 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yup, this is a good choice if you do a full standalone and want to get rid of the drive by wire, you will have to machine a plate to make it fit, run a cable to your gas pedal, fab up a mount to make it work right and then make a few other small adjustments.
it is 90mm and you will need to make sure your intake piping is that large plus port out the neck of your plenum as well.
Old Jan 11, 2007 | 02:50 PM
ACEMAN's Avatar
ACEMAN
Master
If you follow this link, you will see alot of the Japan tuners are using the Q45 Throttle Body on their 350z's.
http://www.jdm-option.com/eng/featur...2/z33_v35.html
So as Jeremy pointed out, it can be done. It just wont be drive by wire. you will need the cable and engine management.
Later
Todd
Old Jan 11, 2007 | 02:58 PM
ESPO 774's Avatar
ESPO 774
gains?
Justin100
Nov 25, 2021 06:26 AM
