Header Install ..thread locker?
Old Jan 12, 2007 | 08:34 PM
derek173's Avatar
derek173
Default Header Install ..thread locker?
Since most people recommend going back and re-tightning the headers after install... Why not just use the highest strength thread locker to prevent it from getting lose?
Is heat an issue with thread locker? I imagine this could be the only reason not to use it
Old Jan 12, 2007 | 08:51 PM
Sean's Avatar
Sean
high temp thread locker is good till almost 500 deg (at that time it is liquid and you can take the bolts out) anyway, you can get header bolts that are ment to lock in place and not get loose, you must check your headers after heating them the first time, and again when they cool back down the first time. If you get alan-head bolts you will be alot happier,no more banging your open end wrench on the header pipes..If you really want to keep the bolts secure, they do have ones with hole in the head for Saftey Wire, thus ensuring they can't loosen.
Old Jan 12, 2007 | 09:02 PM
Forever Z's Avatar
Forever Z
Derek, as far as going back to re torque everything. I have yet to find time to do that. It's been about 3000 miles and all seems well. My advice is to go to sears and buy these.
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
And you this as your instructions...
http://www.350zforum.com/tech/NISMOR...neheaders.aspx
I installed headers in a carport in two days by myself with little or no expierience. It sucked, but I'm proud to say I did it
Old Jan 12, 2007 | 10:28 PM
derek173's Avatar
derek173
EDIT... got it working... copy and paste FTW
Old Jan 13, 2007 | 08:11 AM
Good point. I have first hand experience with header bolts working loose. Then having to install the bolts again using Loctite. So essentially I installed the headers twice.
Do it right the first time.
Old Jan 17, 2007 | 12:47 AM
derek173's Avatar
derek173
bump for more opinions
Old Jan 17, 2007 | 09:14 AM
rlwjr1's Avatar
rlwjr1
The problem is not so much loosening but stretching. As the headers,bolts,gasket, and engine expand and contract from the heat cycles everything moves about and takes a set. What I have done on many header installs is to run the engine to operating temp, let it cool off completely, tighten the header bolts, and repeat. Never had a blown gasket or leaking gasket. Never used Loctite either. Remember to use COPPER anti seize on steel or stainless steel bolts going into aluminum exhaust ports.
Old Jan 17, 2007 | 09:16 AM
rlwjr1's Avatar
rlwjr1
<-------- Look, I just passed 90 posts. Yeah me!!!
Old Feb 20, 2007 | 05:44 PM
derek173's Avatar
derek173
bump.........installs coming up soon
Old Feb 20, 2007 | 05:46 PM
Nexx's Avatar
Nexx
lol, thats just about everyone's feelings after installing headers on a Z, its sucks!
