Nismo hardware?
Old Jan 26, 2007 | 01:29 PM
ESPO 774's Avatar
ESPO 774
Default Nismo hardware?
just picked up a nismo exhaust, but it has no hardware or gaskets. I know mynismo.com has the hardware/gasket kit for $70, but does that include all of the necessary bolts? it doesnt look like it. also is there any cheaper alternative? thanks in advance
Old Jan 26, 2007 | 02:39 PM
Missing hardware is a pain in the butt. 2 and 3-bolt gaskets are pretty much standard. You can get them at any auto parts store. I recommend quality nuts, washers and self-locking bolts If your auto parts does not have these, check with a marine store.
Old Jan 26, 2007 | 03:10 PM
ESPO 774's Avatar
ESPO 774
can i use the bolts off my stock exhaust?
Old Jan 26, 2007 | 05:47 PM
THE TECH's Avatar
THE TECH
^^yup!
Old Jan 26, 2007 | 06:34 PM
jondimellow's Avatar
jondimellow
for the gaskets, u can even go to the autoparts store and get a sheet of it and cut it ureself..... like 5 bucks max.
Old Jan 26, 2007 | 09:37 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
If I remember correctly, the stock bolts are captured on the stock system. You can reuse the nuts though.
Another thing I can't remember on the Nismo kit, doesn't the back box go on with an O-ring instead of a gasket (like stock, only bigger)?
Sorry I don't have definitives, I installed this thing years ago.
Chris
Old Jan 26, 2007 | 10:01 PM
BhashaZ's Avatar
BhashaZ
This is what you need:
gasket 60x2
gasket 76.3x1
ring gasket x1
bolt(M10x35) x2
bolt(M10x20) x2
spring washer(M10) x2
flange nut(M10) x6
nut(M10) x2
M6x18 bolt(for grounding) x1
M6 nut(for grounding) x1
(units in metric)
Old Jan 28, 2007 | 07:17 AM
ESPO 774's Avatar
ESPO 774
x8 m10 nuts, but only x4 m10 bolts? i dont get it.
Old Jan 28, 2007 | 08:13 AM
BhashaZ's Avatar
BhashaZ
Yeah I was confused about this too, but I think that's all you need. It's been a while, but I think you either re-use a few bolts or something.
Check my old thread for info: https://my350z.com/forum/intake-exhaust/191809-nismo-exhaust-instructions-sheet.html
Old Jan 28, 2007 | 08:23 AM
ESPO 774's Avatar
ESPO 774
so did the cat/ypipe bolts get re-used? also im confused about the ring gasket. where can i find one of these? do they come in sizes? i need a 3"? and how does it attach?
Old Jan 28, 2007 | 08:35 AM
BhashaZ's Avatar
BhashaZ
I think they might have, but we installed it last year, so I don't remember. If you want, just also get a few extra bolts. As far as the ring gasket, it's basically like the one you currently have. It's used as a gasket between the mid-pipe and the muffler. Unforntunately I'm not sure what size that is, but I believe it is bigger than stock (referring to the o-ring gasket).
Also, this is the step-by-step instruction that we used: http://g-owners.com/article_read.asp?id=39
It was very helpful as well. And since the Nismo is exactly the same as the Fujitsubo, the instructions will be the same.
Let me know if you have any other questions, and I'll try to help you out.
Old Jan 28, 2007 | 01:24 PM
ESPO 774's Avatar
ESPO 774
pep boys and auto zone do not carry 3" exhaust gaskets. anyone know where i can pick up one, and also the 3" ring gasket? if i went to the dealer would they be ridiculously expensive?
Rowlett
Misc.
Oct 2, 2015 10:38 AM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
