RPM drops
Old Feb 2, 2007 | 08:26 AM
SunsetSunrise's Avatar
SunsetSunrise
Default RPM drops
After installing the 1/2" spacer my RPMs became somewhat rough and now that its cold, my car stoles sometimes while.
Usually that happens when I drive on the highway at high RPM and then put it in neutral.
Happened twice so far.
What to do?
Old Feb 2, 2007 | 08:57 AM
Ken@Performance's Avatar
Ken@Performance
Performance Nissan
Sounds like you might have a leak coming from the plenum area. I would check around for some loose hoses or perhaps something got caught in between the plenum and not letting it sit properly.
Old Feb 2, 2007 | 09:49 AM
SunsetSunrise
hmmmm
damn, its too cold outside to play around under the hood
Old Feb 2, 2007 | 10:37 AM
Cannysage's Avatar
Cannysage
you better reinstall it.. you prolly have a bent gasket or something.
Old Feb 2, 2007 | 10:51 AM
SunsetSunrise
ouch.
gasket seemed fine.
will inspect it over the weekend.
Old Feb 2, 2007 | 12:07 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would just raise idle, it will almost definitely solve all your problems.
Nissan dealer can do it using the "consult" device
Old Feb 2, 2007 | 12:10 PM
Cannysage's Avatar
Cannysage
I wouldn't raise the idle.. this is a common issue and definitely sounds like a leak issue. check your intake tubing to see if it's loose, as well.
Old Feb 2, 2007 | 12:20 PM
Jay'Z's Avatar
Jay'Z
He is definately right!! Idle is too low and will sometimes stall the car when you put it into neutral.. It should go away after the ecu learns it.... Trust me.. Or bring to nissan and tell them to raise the idle by using the drive by wire, should be free(SGP's Mark educated me)..
Old Feb 2, 2007 | 04:04 PM
SunsetSunrise
Well it drops and then gets up to the normal level.
I am not sure NISSAN will want to do work under warranty once they see a Giant spacer there.
lol
Old Feb 2, 2007 | 11:02 PM
Sleeper01's Avatar
Sleeper01
Where in NYC are you?
Old Feb 3, 2007 | 05:03 PM
SunsetSunrise
Brooklyn, you?
Old Feb 3, 2007 | 07:35 PM
Sleeper01's Avatar
Sleeper01
Queens
Old Feb 3, 2007 | 07:37 PM
Z-CRA-Z's Avatar
Z-CRA-Z
Definitely a leak!!
I put my spacer on and didn't have to adjust anything.
Old Feb 4, 2007 | 01:46 PM
SunsetSunrise
if you ever come to BK let me know, i am down to meet.
I am right off Belt Pkwy.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
