Will nismo get louder in time??
Old Feb 16, 2007 | 01:15 PM
halfass872's Avatar
halfass872
Default Will nismo get louder in time??
Finally got my nismo exhaust today, and i love it!!! It looks and sounds fantastic! But i have one question. I've been told it usually gets louder as you accelerate. Mine tends to get loud 'till about 4000 RPM, then from then on sounds stock (from inside the car) will it get more even in loudness in time? Is there a "break in" period for new exhaust?? (My first aftermarket exhaust) Thanks!!!
Old Feb 16, 2007 | 01:18 PM
kpiskin's Avatar
kpiskin
If there is, it's very gradual. I didn't really notice any change. I installed a spacer awhile afterward and it mellowed the sound out at idle.
Old Feb 16, 2007 | 03:46 PM
halfass872's Avatar
halfass872
Thanks!
Old Feb 16, 2007 | 03:53 PM
igetgreens's Avatar
igetgreens
i got my nismo exhaust today too and it sounds GREAT. but yeah, it does get pretty loud up till like 4500 for me and then after that it kinda mellows out, but still louder and deeper than stock. the highest i took it up today was 5000, so maybe the sound kicks back up again once you are near redline
Old Feb 16, 2007 | 07:52 PM
gsazabi's Avatar
gsazabi
If you want it to be louder, just add Crawford HFC; it'll sound SICK
Old Feb 16, 2007 | 08:49 PM
mikead_99's Avatar
mikead_99
I think any exhaust gets louder over time, or intially anyway. It has to do with the baffling material in the muffler(s) cooking, compressing, getting coated, etc. After that, 1000 miles or so, prolly a little more +1 to what gsazabi said if you want more sound. Actually doesn't have to be Crawford HFC, AAM HFC will make it loud as **** too and I'm sure others, or just TP will do the same and more.
Old Feb 17, 2007 | 04:25 AM
halfass872's Avatar
halfass872
Kinda nervous about Test pipes. So i'm leaning towards the HFC. I love the sound of my Nismo. I just want it a tad louder and no rasp.
Old Feb 17, 2007 | 04:30 AM
my2004Z's Avatar
my2004Z
Here's what the Nismo exhaust sounds like going by at 100 mph and 5000+ RPM.
100 MPH Fly By
Old Feb 17, 2007 | 04:32 AM
halfass872's Avatar
halfass872
100 MPH Fly By
Nice!
Old Feb 17, 2007 | 05:29 AM
NIZZMO's Avatar
NIZZMO
My Nismo exhaust sounds louder than the posted sound clip but I also have the Injen intake and the Kinetix V4 plenum. Just avoid test pipes , we have a local member adding Crawford HFC's and I was told they sound great with the Nismo so after I hear his setup and like it that's the route I will be going.
BTW I like the sound of my setup just fine Im looking at HFC,s to get a little more HP for my NA setup.
Old Feb 17, 2007 | 10:58 AM
gsazabi's Avatar
gsazabi
I suggest you skip on test pipes and go straight to HFC.
I think Nismo with HFC sounds just perfect..perhaps a little too loud to some.
Nismo with test pipes get loud...I mean LOUD!
I used to have both setups and when I put the test pipes on
I couldn't drive the car around because it was so embarassingly loud.
Old Feb 17, 2007 | 11:06 AM
jaZon350's Avatar
jaZon350
I kinda noticed when the car is still cold the Nismo isn't as loud, but when the car gets hotter and warmed up to operating temp the Nismo gets that nice loud throaty sound.
-jason
Old Feb 17, 2007 | 12:58 PM
halfass872's Avatar
halfass872
Just a quick update if anyone cares. I've put just at a hundred miles on it and now it has really opened up! Did some highway driving, seemed to help. This exhaust is great!!! It sounds even better now that it has "broke in" some. Don't think i will be getting HFC's, i really don't want it any louder then it is now. Thanks for all of yal's help!!
Old Feb 17, 2007 | 03:37 PM
Ninja350Z's Avatar
Ninja350Z
Living in 350Z
Default Louder
It will get louder, mine has gotten alot louder over time. Dont add the HFCs to your Nismo will make it sound raspy.
This is about the best sound clip i have of mine
http://video.google.com/videoplay?do...35922241&hl=en
Old Feb 17, 2007 | 05:46 PM
MyFairladyZ2006's Avatar
MyFairladyZ2006
Hey Ninja350Z nice video.
Do you have any other mods?
Old Feb 17, 2007 | 05:49 PM
Ninja350Z's Avatar
Ninja350Z
Living in 350Z
Default A Few
Here is what I have done so far. I have the Nismo V2 parts listed cause she is in the bodyshop getting the V2-wing, bumper and canards right now.
ENGINE
HKS Supercharger
HKS Intercooler
HKS Oilcooler
HKS Fuel System
Altered Atmosphere ECU Flash
RC 440cc Injectors
NGK 1 Step Colder Plugs
Nismo R-Tune Cams
Nismo S-Tune Exhaust
Nismo Oil Cap
Nismo Radiator Cap
Koyo Radiator
Flex-A-Lite Low Profile Fans
Greddy Catch Can
Stillen Engine Dampner
Stillen Grounding Kit
Altered Atmosphere Angled Plenum Spacer
Samco Hoses
Samco Hose Clamps
JWT Clutch
JWT Flywheel
Custom Painted Engine Cover
Custom Painted Brake and Battery Covers
ALL Tuning and Engine work done By Altered Atmosphere Motorsports
All fluids MOTUL
ENGINE MANAGEMENT
OEM E.C.U with Custom Altered Atmosphere Motorsports Flash Inc/speed limiter removal, 7200 RPM redline
HKS F-Con SZ E.C.U. Piggyback
HKS Navigator Engine Management System with 3 Engine Maps plus Boost, Air/Fuel, Water Temp, Air intake Temp, Knock Sensor and Fuel Cut readouts.
SUSPENSION / BRAKES
ATS Carbon LSD
Nismo Differential Cooler w/ breather hose
Nismo S-Tune Sway Bars 36mm/Front 22mm/Rear
Nismo S Tune Shock and Spring Kit lowered 20mm
JIC Magic Aluminum Strut Bar
FRONT
Rotora 6 Piston Calipers Custom Silver Paint
Rotora Slotted 355 Rotors E Coated
Rotora Stainless Steel Brake Lines
Axxis ULT Ceramic Pads
REAR
Stop Tech rotors
Stop Tech Stainless Steel Lines
Hawk HP Pads
EXTERIOR
Nismo RS concept hood
Nismo V2 Front Bumper w/canards
Nismo Side Skirts
Nismo Rear Under Pieces
Nismo V2 Wing w/carbon fiber center
Nismo Carbon Fiber Pillars
Nismo LMGT-4 Wheels 18x8.5, 18x9.5
Nismo Lug Nuts
Toyo T1R Tires 245/40, 275/40
Nissan LED Taillights
Nissan Clear Corners
S2000 Short Antenna
Tinted windows incl windsheild
INTERIOR
Sparco Torino Seats
Sparco Harnesses
Sparco Harness Pads
Nismo Titanium Shift ****
Nismo Floor Mats
AUDIO
Pioneer AVH-P7500 Touch Screen DVD
JL Audio Stealthbox w/2 JL Audio 10w3
JL Audio 1000w Amps X 2
Boston Acoustic Speakers
Memphis Capictor
GAUGES
Autometer Boost Gauge
Autometer EGT Gauge
Autometer A/F Gauge
Triple Pillar Pod
HKS Navigator
Old Feb 17, 2007 | 05:55 PM
MyFairladyZ2006
WOW!
LoL
Where did you order all your Nismo exterior parts? Those are next on my to-do list!
Please post pics when you get her back!
Old Feb 17, 2007 | 06:07 PM
Ninja350Z's Avatar
Ninja350Z
Living in 350Z
WOW!
LoL
Z-1 Automotive, Adam is great to deal with, good guys.
Obadabot
Jun 18, 2023 11:31 PM
nanotech
Oct 2, 2015 05:02 AM
