Thinking of going back to stock air box...
Old Feb 17, 2007 | 10:52 AM
halfass872's Avatar
halfass872
Default Thinking of going back to stock air box...
I've been toying with the idea of yanking my pop charger and putting in the 06' air box. It gets pretty hot here in the summer, and i do alot of stop and go traffic driving. And i figured with the sealed enclosure, and velocity stack i'd benefit. I'll prob make a trade for something like my pop charger with only 2000 mis. on it (Never seen rain or snow driving) for 06' box with new K&N drop it. Is this a stupid idea??
Old Feb 17, 2007 | 11:34 AM
AWDBall20's Avatar
AWDBall20
Im staying stock air box so id say go for it, intake mods just lean out fuel and dont really gain hp they just trick the ecu into thinking its so. Granted the filter does flow better that can be solved with a drop in from K&N.
Old Feb 17, 2007 | 11:55 AM
Mike Wazowski's Avatar
Mike Wazowski
honestly, since the air box is a cold air to start with I would say go for it and do the K&N drop in filter.
Old Feb 17, 2007 | 12:41 PM
halfass872's Avatar
halfass872
Great thanks!!
Old Feb 17, 2007 | 12:51 PM
halfass872's Avatar
halfass872
Pop charger for sale!! LOL see my thread...
https://my350z.com/forum/showthread.php?t=250171
Old Feb 17, 2007 | 01:05 PM
plumpzz's Avatar
plumpzz
ive been thinkiing abou tit too, but im too lazy to take off the popcharger since its already in.
Old Feb 17, 2007 | 01:08 PM
black06z's Avatar
black06z
Same here. Ive been thinking about taking it off, but there would also be a sound loss in the front end that im used to.
Old Feb 17, 2007 | 01:14 PM
Hella's Avatar
Hella
If you are stock otherwise I would take it out. Once you have the breathing mods I think the stock box is a bit restrictive.
Old Feb 17, 2007 | 01:15 PM
arodbrs's Avatar
arodbrs
Thumbs up stay with oem air box
This guy is a genius............................ j/k.. honestly i left my 06 stock air box and i dropped in a K&N air filter and it sounds great and runs good compared to oem air filter. Nissan modified the airbox in the 06 model z, to acquire more air by enlarging the opening and modify the inside of the box.
Old Feb 17, 2007 | 02:40 PM
tranceformer95's Avatar
tranceformer95
I had a popcharger on for about a month, then i took it off and reinstalled my stock-airbox with drop-in K&N filter. I'm deciding between an '06 airbox or a Stillen intake.
Old Feb 17, 2007 | 03:06 PM
jtoddj's Avatar
jtoddj
I made just the same amount of power with a drop in as I did with my AEM
Old Jun 23, 2007 | 02:02 PM
Vin Diesel's Avatar
Vin Diesel
I got a cousin Vinny....
Old Jun 25, 2007 | 07:43 AM
gothchick's Avatar
gothchick
I also had a popcharger on for about a month, the heat soak was a joke, so I took it off and reinstalled my stock '06 airbox with K&N Dropin filter. I recently ditched the K&N Dropin for an Amsoil Dropin since the Amsoil has better flow than the K&N and better filtering capacity.
Old Jun 25, 2007 | 08:36 AM
devildoc's Avatar
devildoc
Same here
Old Jun 25, 2007 | 09:12 AM
metal_gear350's Avatar
metal_gear350
i so far have stayed stock, but lately the stillen has been calling my name
Old Jun 25, 2007 | 10:32 AM
XuperXero's Avatar
XuperXero
Got any proof that it has better flow? I can't seem to find the cfm ratings for any of these drop-in filters...
How bout other drop in's?
Old Jun 25, 2007 | 10:44 AM
gothchick's Avatar
gothchick
Yeah, I still have the Amsoil and K&N boxes at home. I'll scan a pic and post it up. They have the CFM ratings...
Or better yet, 'til I get home, check this link out...
http://www.thebestoil.com/eaa.asp?en...FSMqgAodiS1k5w
Edit:
Took this off another website comaring K&N to Amsoil. It's kind of a sales pitch, but here it is:
http://www.oilsandlube.com/dustk&n.htm
This website page describes the air filter test equipment we have and how various types of air filter sections perform when tested on this machine.
The air filter test machine consists of a three inch diameter clear plastic PVC tube coupled to a vacuum motor. The top of the tube has an aluminum mounting plate for air filter sections and the bottom of the tube has a place to install an oiled piece of white foam pad to prevent dirt particles from being sucked into the motor and destroying it.
Note: This is not intended to be a scientific test; it is a simple comparison test with only one variable changed from test to test (air filter sections). The air filter test machine consists of a three inch diameter clear plastic PVC tube coupled to a vacuum motor. The top of the tube has an aluminum mounting plate for air filter sections and the bottom of the tube has a place to install an oiled piece of white foam pad to prevent dirt particles from being sucked into the motor and destroying it.
A 5 x 5 inch. section of a freshly oiled air filter is placed on the mounting plate and secured. The test machine is turned on and one teaspoon of Standardized Air Filter Testing Dust is sprinkled on the top of the filter section. The machine is then shut off and the filter section and pvc tube is removed in order to inspect the white oiled foam pad. In each test of a oil-wetted gauze filter test (K&N), the oiled foam is gritty and full of test dust particles as is the inside of the PVC tube. A paper air filter also lets the test dirt through but varies depending on the quality of the paper filter.
When the exact same test is replicated with a section of an AMSOIL 2-Stage Foam Air Filter using an entire bag of test dust there is absolutely no test dust particles on the oiled foam.
If the same test is run again, only this time lightly tapping the top of the filters, simulating vehicle impacts and vibrations, the test dust ingress is even worse for the oil-wetted gauze (K&N) while with the AMSOIL foam filter there is still no test dust particles on the foam.
This test shows how oil-wetted gauze and paper air filters do not stop dirt particles as well as an AMSOIL Two-Stage foam filter does. Sure, they may flow air very well on a flowbench, dynomometer and in high performance applications, but what good is all the airflow if the filter isn't trapping and holding all the abrasive dirt particles?
Additionally, take a look at the oil used on the oil-wetted gauze filters. It is a lightweight viscosity spray oil. Put it between your index finger and your thumb and pull them apart and you'll see that very little happens. In contrast, try the same thing with AMSOIL Foam Air Filter Oil, which has a very high viscosity and when you pull your fingers apart the oil stretches because of it's extremely high tack properties. This is what you need on a filter to stop dirt dead in its tracks.
Same thing goes for other manufactures of foam air filters, like UNI, for example. They also make an excellent foam air filter and use a very high tack oil. Fact is, there is absolutely no better air filtration media than oiled foam. Take a look at every off-road motorcycle that is used in extremely dusty environments. They all have oiled foam air filters.
We have received numerous questions and concerns from K&N filter users with the Dodge Cummins Turbodiesel and the Ford Powerstroke Diesel asking why the air filter restriction gauge never moves when using a K&N air filter. The answer is that the K&N has higher airflow capability due to larger holes in the filtering media and it apparently does not stop enough dirt particles to ever make the filter become restricted enough to make the restriction gauge move. Take the K&N out and put in a paper filter an eventually the paper filter will trap enough dirt that the restriction gauge will move. Same thing with the AMSOIL foam air filter: as it traps dirt, eventually it will cause the gauge to move, but it will take a longer period of time due to it's superior filtering AND airflow capabilities. This same issue was addressed in the Q&A section of a recent issue of the Turbo Diesel Register magazine
We have no issue with oil-wetted gauze filters other than our test equipment indicates that these filters don't stop all the small dirt particles. They do flow air well, but what good is all the airflow if the filter isn't trapping and holding all the dirt particles?
So, you may then ask why do so many race cars use oil-wetted gauze filters? Our opinion is that they are interested in airflow and horsepower. Racing engines get disassembled, inspected and re-built at least once a season and in many cases several times a season therefore dirt stopping ability is not the primary concern. And, where dirt stopping ability is a concern, such as off-road racing, one manufacturer of oil-wetted gauze (K&N) offers a foam wrap as described below.
An advertisement in the new products section of a performance racing publication shows that K&N has released an open cell K&N Airforce Precleaner for their 14 inch diameter round filters. It is an open cell foam wrap with a special oil. The heading on their advertisement says: "Keep 90% of the Dirt Out". We say, ok great. Now, what about the rest of the K&N's for everyday car and truck use? Don't they also need a foam wrap?
Our Conclusion is just as we stated previously: There is absolutely no better filtering media than oiled foam.
The AMSOIL 2-Stage Air Filter is a maximum performance, extended life filter that combines the very best possible filtration with better air flow characteristics. Its two thick layers of oiled polyurethane foam allow air to pass through virtually unrestricted, while stopping and holding destructive dirt and grit.
The AMSOIL 2-Stage Foam Air Filter is the best form of insurance that you can buy for your engine. Its washable and reusable design provides many thousands of miles of trouble-free service. The AMSOIL 2-Stage Filter is designed to last indefinitely with proper service. Under normal driving conditions, it may be used for 25,000 miles or one year between cleaning and servicing. Under dusty driving conditions, it should be cleaned and serviced more frequently.
How does AMSOIL , Oil-Wetted Gauze (K&N) and Paper Air Filters Compare in Industry Standard Testing?
Here's a more detailed test procedure and conclusive results covering AMSOIL vs. K&N and paper air filters according to the Industry Standard Society of Automotive Engineers (SAE) test standard SAE J726.
Your car's engine "inhales" air that is mixed with fuel for combustion. But air contains an incredible amount of suspended dirt - typically 400 tons of it in a cubic mile. Much of this is microscopic dirt, extremely abrasive, that can cause serious damage inside the engine. Consequently, an air filter is a
An air cleaner must not only trap as much grit as possible, but it should do so without "smothering" the engine, restricting its vital airflow. Thus the most desirable performance characteristics for an air cleaning device are high dirt-trapping efficiency, and minimal airflow restriction as the dirt accumulates.
The Society of Automotive Engineers Test Code J726 specifies the procedures, conditions, equipment, and report format which air filters can be uniformly compared. A standardized dust contaminant is introduced into a specially designed testing apparatus at a controlled rate. Most of the dust will be trapped in the filter undergoing the test; the remainder is captured in an "absolute filter".
The air pressure upstream and downstream of the test unit is monitored. The test terminates when the pressure differential causes a predetermined amount of fluid displacement on a water manometer. By quantifying and comparing weights, pressures, and elapsed time, the experimenter can determine a filters efficiency, capacity and airflow-based life expectancy.
Our J726 trials were conducted at an independent testing facility in the upper midwest. The tests compared Motorvator, K&N, Accel, Fram, and AMSOIL products. The results? AMSOIL proved vastly superior to the competitors' air cleaners as the only air filter to consistently score high marks in all three vital areas of airflow, efficiency and capacity.
The AMSOIL 2-Stage Air Filter traps airborne dust with 99% efficiency; it holds an incredible 281 grams of contaminant (that's over half a pound); and it outlasts the competition. It performs two to four times longer than the others. That's why AMSOIL can confidently recommend a 25,000 mile/1-year service life. And the 2-Stage is actually re-usable, with proper cleaning and re-oiling.
How does AMSOIL do it? Two different densities of lightly oiled polyurethane foam surrounding an expanded metal cage, precisely assembled by careful craftsman in AMSOIL's own manufacturing plant- that's how!
Old Jun 25, 2007 | 11:01 AM
twotonez's Avatar
twotonez
^^ dam... that about says it all lol
Old Jun 25, 2007 | 11:09 AM
pss350z's Avatar
pss350z
Do the K&N dropins really produce a different sound from the stock filters?
Old Jun 25, 2007 | 11:20 AM
gothchick's Avatar
gothchick
Why is everyone so concerned with intake 'sound'? I'd be more concerned with how the components perform... But that's just me.
