y-pipe modificatin
Old Mar 6, 2007 | 08:38 AM
affirmed's Avatar
affirmed
Default y-pipe modificatin
Hi,
This is my first post. I have been following the forum for about a year and I have finally joined in. I need advice as to what to do.
I want more power out of my stock exhaust. I want to change to an after market y-pipe. I also want to keep the exhaust sound as stock as possible. If I change the y-pipe only, would I run in to any performance issues? Also, My budger is low, so I'm only planning to spend about 400 for the y-pipe. Which one should I get?
I welcome any information about this modification.
Danny
Old Mar 6, 2007 | 09:32 AM
Pooplet's Avatar
Pooplet
just get the megan racing resonated testpipes and y-pipe...wouldnt ven run 400 total.
Old Mar 6, 2007 | 09:38 AM
BaTMan_4's Avatar
BaTMan_4
Check the link...it might help...
https://my350z.com/forum/intake-exhaust/246076-y-is-a-400-y-pipe-better-than-a-130-y-pipe.html
If you want the most power from your stock exhaust a y-pipe is not the solution...Test Pipes (to noisy) or HFC's (pricey, but stay close to stock sound) would be the solution. Y-pipes are an essential though once you install TP's or HFC IMO though...its all a package
Old Mar 6, 2007 | 09:39 AM
03zsmith25's Avatar
03zsmith25
man youre not gonna get much power at all from that, so dont expect much. a little louder and maybe a few horses. but good luck
Old Mar 6, 2007 | 12:27 PM
affirmed's Avatar
affirmed
Default y-pipe
I was told by vendors that the power gains in the exhaust systems were mainly created by the y-pipe.
Is there any evidence of this?
Danny
Old Mar 7, 2007 | 09:28 AM
affirmed's Avatar
affirmed
Default y pipe
which one to buy from all the brands.
Old Aug 7, 2007 | 02:14 PM
ameer_4_u's Avatar
ameer_4_u
bump
Old Aug 7, 2007 | 02:17 PM
iceburns288's Avatar
iceburns288
No. Don't. Please.
Old Aug 7, 2007 | 03:34 PM
Question
What did you get?
Old Aug 8, 2007 | 09:05 AM
Gsedan35's Avatar
Gsedan35
Here are pics of the oem Y-pipe without the protective heat shielding.
Notice the crush bends and and overall design including the merge area.
Some demensional info for the oem Y-pipe
ID at the point where the pipe bolts to the cat conv 50mm or fraction below 2"
ID at the point where it hooks up to the B-pipe 61mm or 2 3/8"
Remember that most aftermarket Y-pipes use 65mm inlet diameters off of the cats and have a 80mm diameter at the B-pipe connection.
If your not modding the rest of the exhaust. It's a bad idea to have a 80mm pipe connect directly to a 61mm oem B-pipe, you'll end up with about a 1/4" ringed wall directly in the flow path. Either use the Tanabe Y-pipe with it's 70mm output or buy the Japtrix B pipe which has a 80mm inlet that taper's down to 65mm when it connect's to the muffler. Or have a exhaust shop weld in transition part to the front of your oem B-pipe to smoothly blend 80mm down to 65mm. http://www.drgas.com/store/product.p...9&cat=1&page=1
Old Aug 8, 2007 | 11:46 AM
WalkerT's Avatar
WalkerT
Professional
That is to painful to look at..... look away ......look away
Old Aug 9, 2007 | 01:32 AM
03trackguy's Avatar
03trackguy
megan racing = junk
Old Mar 18, 2009 | 02:49 PM
ChuckD05's Avatar
ChuckD05
Originally Posted by 03trackguy
megan racing = junk
why do you say that ?
Old Mar 18, 2009 | 07:46 PM
OldDirty Z33's Avatar
OldDirty Z33
megan racing = junk
Old Mar 23, 2009 | 11:23 AM
ChuckD05's Avatar
ChuckD05
I have evo2 exhaust with megan resonated test pipes I have zero rasp and no problems with the welds. Going good for 10k+ miles
Old Mar 23, 2009 | 06:26 PM
Thermal1's Avatar
Thermal1
Save up a few bucks and get something you know you won't regret later. I am super pleased with my Berk HFCs and Motordyne Y-pipe.
350Shadow
Sep 22, 2015 08:30 AM
dklau33
Apr 8, 2004 09:06 PM
